1 - 12 of 12 Posts
06 mitsubishi eclipce gt-se v6 106k miles , 00 sportage base 72,802 miles 2wd... purple...
it should with no problem but dont quote me on it. im sure aqua or cruise will chime in and they will know for sure.
what happened that u need to swap motors?
:eek:that will do it. are you going to get the motor altogether or just the block area?
if possible you could go to a junk yard and get the things u need.
it would prob. be cheaper to just get the block and rod then the whole thing
2000 Sportage 4x4 , 1998 Saturn SC2
Call the Kia dealership and talk to someone in the parts dept.. I am almost certian they will swap OK..Sorry to hear about your engine ...
Will a engine from a 2002 sportage work in a 2000 sportage
Yes, it is the same motor - same bolt patterns, etc. - anything past the rear main seal is trans-related, so if the same transmission type (auto, 5speed) as your current motor that would be best. :D
Regards,
GottaCruise
i have to ether get a block that has good cylinder walls or have this one redone if poss.
1 - 12 of 12 Posts
