First, a question that seems to be asked a lot... where are the spark plugs? Under the removable plate on the top of the engine? I looked and I didn't see them in there. Are they under something else?
Second, a few days ago my car stopped starting literally within minutes. I left work, it started fine. Then I went to get gas 2 blocks away, and when I turned the key to leave, nothing. It jumped, so I thought it was the battery. The next day, after buying a brand new battery, it started fine when I left for work in the morning. But then when I started to leave for lunch, nothing. Not even a click. It jumped again, and ran fine all the way home. But today, while trying to figure out what the problem is, it won't even jump. No lights come on anywhere, and the horn barely even works.
Also, I recently had a new stereo installed, which kept popping fuses. It would blow a fuse every single day, but just the stereo fuse on the inside fuse panel. Could these 2 things be related? Could a short in the stereo system wiring be draining the battery? Or something else?
