Kia carnival 2003 2.5 V6
Heya!,
I'm in the middle of replacing the timing belt on a Carnival with the 2.5 V6, since it's my first time working on it and I don't expect to do much to it I don't have a workshop manual, I have taken off the engine mount, accessory belt and the timing cover below, and I was hoping that someone could clarify the torque specs to me for the following components: timing belt rollers, tensioner, timing belt cover, engine mount and accessory belt pulleys, hope that covers everything that was taken off and needs to be torqued back on.
Thanks ahead!
In the absence of a repair manual break away torque is close to actual torque.
If you did not record break away torque hopefully someone will provide you with the proper data....
