1 - 20 of 35 Posts
2001 Kia Sedona 2.9 CRDi SE & 2004 Accord 2.2I-CDTI Exec
Hi all,
Tonight I did a bit of part removal in my engine bay, Primarily to do a final final check my injection system is common rail...it is...phew!!
1. Since I got it, its had the sedimentor light triggered all the time. It supposedly had a new fuel filter 9000 miles ago according to its service record. Anyway, I pulled the filter out and drained it. Its drain plug was actually combined as a water sensor plug. But when I primed the system up again an started the car....the light was still on, so I guess I've got a duff sensor.
2. I think my cooling fan is jammed, It might tie in with my suspension the A/C isn't working very well. I could hear the fan buzzing but it was not happy to freewheel. Oh well that another job tomorrow. It looks like its held on by two screws and the bottom. I hope I don't have to strip all the rad & condensor off...
3. Have a look at these snaps of this beefy engine :-
http://tinyurl.com/c6y5q
http://tinyurl.com/bs335
http://tinyurl.com/c9mhm
http://tinyurl.com/9qked
http://tinyurl.com/afgjm
http://tinyurl.com/abs7q
The one thing that concerns me is the soundproof foam had melted all over the no1 & No4 injectors. I later had to srape it all of the injectors with a screwdriver.
Anyone ever seen any post about duff sedimentor sensors or melting foam before now ?
Okay then,
So far I've stumbled across :-
-rusty tailgates
-sedimentor light sticking on
-melted foam on engine cowel caused by 'loose injectors'
this in in 3 days of ownership.
Can you elaborate on what needs doing to rectify the injectors and why isn't it a saftey recall given the pressure of the fuel????
-what other 'common' flaws should I look at for, eg is the busted cooling fan common to fail as well?
Nope, only got it on Saturday. But I see a post about a German plugin device on Ebay,
Was it someting that pluuged in between the multiplug right at the front of the engine ( the purple coded one )
I've heard about cheap plug-in devices which crudely play around with the signal from one sensor ( forgot which )But I thought the best ones were the devices which plugged into the ECU itself.
I note the other posters comments suggesting I've bought a lemon. But its a leather trimmed 1-owner lemon I only paid £6.4k for.....
Hello ebod,
Yes I think so but my engine is diffrent to yours
I know of two German sites I went with the Profitune product not just because of Dubana's and Clarksonly postings, but there is a diffrence in price Profitune
being the more exspensive and I do believe in most cases you get what you pay for, I did e-mail the other company with details of my vehicle, they wrote back saying they couldn't supply.
Where did you get yours from?
I saw your pictures, excellent, I wish more people would do it, by the way I would do so on this forum, I'm doing something wrong, how does one attatch pictures?
Seacam
G
Timing Belt Sedona
I have had my timing belt change 3 months ago, when I pick it up my Sedona was ideling rough. In the last 3 months the fuel pump, altanator, battery and a cable to control fuel blew. I ask the dealer if these problems could of happen because the timing belt in not in right...he said no and that the timing belt is in right......can anyone help me....My Sedona still idels rough and waiting for something eles to go wrong!!!!!!!!!!!!
Loose injectors..
The allen bolts that secure the clamp for the injectors can work loose, a redesigned bolt was introsuced, just a few mm shorter to fix this.
Just check your bolts are done up tight, but not to tight as they have a habit of snapping! and that will cause you some serious grief!
Timing belt:
If it's tidling rough and this has only happened since belt change then I'd guess thje valve timing is out, needs to be checked, an engine will run with it 1 maybe 2 teeth out, but won;t run right at all.
Discussion Starter · #10 ·
Thanks Murphwiz,
I'l take a further look at the clmap bolts in the near future , I will probably buy a fresh set. I'd love to see KIA try and charge something stupid like £10 for four screws...
Seacam, the way to post pics ( my way anyway ) is to use two websites :-
First, set up a free account on .www.photobucket.com , upload your snaps and use the links it give under the pics and then go to www.tinyirl.com and paste the links into that site. You then end up with a batch of cute little links to the snaps.
next issue:
Last night I removed the lower bolts to the cooling fan becuase it was crudded up with leafs and dirt.The fan was just grating. I still don't know for sure whether the fan is working so next I'll put 12v across the terminals. I am now also convinced the A/C isn't functioning. If it was then the fan would kick in. All the piping and condenser looks a-okay so I think I've either got a leaked out system , a knackered compressor or a simple electrical glitch actuating the system.
Does anyone know of any common A/C faults on the Sedona before I see an aircon specialist for a check-report?
my solenoid broke on my aircon.. the car was 14 months old and the dealer said "We will fill it with gas at £120, if we find any leaks you do not have to pay anything". I contacted kia and they said "they hope there is a fault as the air con should last about 3 years"... luckily it was just "another" fault.
Discussion Starter · #14 ·
Anyone know the location of the solenoid / relay ?
Come to think of it , has anyone got a CDrom manual for the Sedona/Carnival covering the CRDi diesel.
I found a german manual in pdf which covered the mk-1 sedona <2001, but my german is pretty scheisser.
KIA Sedona 2004
Hello Clartsonly,
If your Kia dealer told you that the air con "should last 3 years" (just on the limit of our guarantee) how come my cousin in California gets a 10 year or 100,000 miles guarantee, AND they cost just over half what we have to pay here in the UK???? Here we only get a 3 year guarantee. Surely Kia wouldn't build the air con to last just 3 years if they offer a 10 year guarantee in the States? That would cost them a heap of money surely?
Just a thought.
John
no the gas should last for 3 years. the gas is not covered on warranty but leaks are.
if I had aircon on full blast everyday and drove for 6 hours a day it would probably only last for 1 year. hence average UK usage should be about 3 years.
my aircon just blew out hot air last year when the fault developed.
Discussion Starter · #17 ·
Well, I've got my local Mr Aircon guy out to see my car tomorrow for a check n' report.
Hopefully it will be a £75 service , top-up etc but I could end up gutted becuase something major is defunct like the compressor.
I'll be back tomorrow night with the results.............
The more you use the Air con the longer it will last.
The AC gas has oil added to it, this coats the pipework when in use, thus not allowing gas to escape, which it will otherwise.
a loss of 10% per annum is considered normal.
Most AC system will run at 60%, just not very well!
I was always told at least once a week for 30 mins or so.
The AC also works very well in the cold rain, easiest way to keep your windows from misting up, AC works by de-humidifying the air, my cars have auto climate control, my last lasted for 4 years and I never touched the AC system once.
1 - 20 of 35 Posts
