Ok, here's the problems I'm having. When I'm driving uphill, which I have to everyday for work, the car loses power. One side of the hill is much steeper, but shorter. I can usually go about 45-50 on this side. The other side is very gradual and long. I can on a good day go 35-40.
Another problem is it jerks back and forth on occasion. It's been doing this a lot less, but still does it. It seems like the longer I run it, like if I go somewhere and leave it running, when I get back in it does it more often. It feels weird when it does it too, like if you gave it a bunch of gas and suddenly let off, then gave it gas again real quick and let it off.
I had the check engine light checked at Autozone and got a MAF sensor error. It wasn't even hooked up. I bought a brand new MAF and hooked it up and the car would start and run for a second, maybe two, then die. The people that owned it before us I think tried to make a racecar out of it. It has an aftermarket cool air intake kit on it. But I did notice there was at least one part missing though.
Another code I got was bad O2 sensor, but the guy said that the MAF could actually be throwing the O2 sensor off.
I have replaced the fuel filter, the spark plugs, the MAF, all to no avail. ANY help is greatly appreciated!
