Help! I need power steering belt adjusted on a 1999 Kia Sportage and can not find anywhere to tighten the belt. Does anyone know how to do this or should I just take to dealer and have it replaced? If so, does anyone know how long would take and how much would cost? Thanks for any help you can give! :confused:
Remove large skid plate from under side (4 bolts) to gain access .
Inspect belt for cracks or missing pieces .
If ok loosen top and bottom bolts, do not remove.
Rotate pump with pry bar, top hole is elongated to allow movement.
If belt is bad you have to remove a/c belt (if equipped) which has a idler pulley , locked in place via center bolt ( just loosen ) there is a adjusting screw, to remove p/s belt.
Try to use Kia or Gates belt.
Tighten bolts .. reinstall skid plate.
Don't know what a dealer will charge but you should be able to complete this a hour. depends on skill level.
chief
