Hello
I nearly ran out of fuel near home, it was jerking and surging. Anyway got fuel but now wont idle and runs rough at low revs. in fact when you pull up it just stops. also the check engine light stays on. it use to come on from every now and then, always has but now stuck on.
just want it to run great again.
To fix this is what iv done.
1 new fuel filter and injector cleaner in fuel
2 disconnect battery to reboot
still not right........but it had a moment when i first put the filter on and started it that it ran great for 5 min but went back to running rough again..duh
my thoughts....has to be fuel related as only started when ran low on fuel.
so dirty injectors?, fuel pump?. air in fuel line?
what do think i should do next and how????????
thanks
thanks
