I have a 97 sportage. 128k miles. its grinding when it goes into gear. the clutch was just replaced. I think the synchronizers are going bad, because shifting at higher RPMs (like 2700 and up) it'll grind going into gear . so i', thinking i will change the gear oil (or at least put an additive in, but the tranny oil looks pretty bad). I hope that'll fix it. what do you guys think?
To follow that up, I have no idea where the filler plug is on the transmission. I've been under the truck all morning, there are a few bolts there on the side of the transmission but im not sure which one it is. I have been searching online everywhere and i cant find it.
Thanks for the help!
