1 - 8 of 8 Posts
99 Kia Elan, 17 Ford Edge Sport, 15 Mustang, 08 Harley Nightrain
1999 Sportage EX Sport Utility 4x4 2.0l. Changed fuel pump, fuel filter, new thermostat and flushed/replaced coolant.. so it started, drove it for 3 days then the other day it started again but while it ran for 2mins I've started to hear the fuel pump slowed /wine down til it shut down and it stalled??? It wont start.. plz help
eg.
USA
2001 Sportage, FE DOHC Engine 5 SPD Manual Petrol
Weird, I can't even hear my fuel pump. You should check some electrical things. It sounds like somethings not matching up. The key turns on, activates the fuel pump relay, the fuel pump runs. Sounds like it's not getting the proper voltage, or it's sucking up dirt, slows down and quits.
Sportage Limited 2001
Need to see if you are getting enough amperage to the pump and a good ground. I use a 55 watt headlamp bulb at work to load test the fuel pump circuit. If it won't turn it on, it isn't going to run a pump. Then you just have to test the ground circuit or pump +voltage circuit.
2001 Kia Sportage Limited 2X2 USA
1 - 8 of 8 Posts
