1 - 1 of 1 Posts
· Registered
I own a 1995 Sportage. It doesn't run smooth at idle & is lacking in power.
I did a compression test and found 2 cylinders a very low.
Are there any common problems with these 2.0 liter SOHC motors ? Like do they blow head gaskets,Valves go bad or rings in 76,000 miles ? It doesn't use much
oil, so I'm thinking valves or head gasket.
*** Is it possible the injector seals could be leaking, causing the compression problem ?? ***
Does anybody know if long blocks are available ? (NEW)
Dondobe
1 - 1 of 1 Posts
