1 - 8 of 8 Posts
2013 Kia Rio Sedan Auto 1.6 Turbo // 2020 Sportage LX FWD
An interesting look at a 2013 Kia Rio 1.6 gdi after 160,000 miles. Still can see the honing marks on the cylinder walls. Two damaged valves (exhaust). The more severe damaged valve had a hot spot on the correlating cylinder wall. I will add the timing chain shoes/guides looked brand new as well. Used valvoline full synthetic it's whole life.
118272
118274
  • Like
Reactions: sooner4x4
Discussion Starter #2
118275
118276
  • Like
118277
Cleaned pistons with break cleaner for pictures. There was a heavy layer of carbon on the top of all
Un cleaned. How it looked when opened. Slight wear on the cam caps, could not feel the wear with my fingernail however I could see it. If doing a head gasket, I would have replaced the valves because of damage, set lash, and reassembled. But just for insurance I would have replaced the timing chain tensioner solinoid band timing chain.
118278
  • Like
2013 Kia Rio LX, auto, red
Rio-t, thanks for sharing the interesting pics and commentary about the motor. Given the volume of discussion and speculation about carbon build up in gdi engines, actual pics and examples of higher mileage engines are pretty rare. Obviously, from your signature your Rio wasn't running a bone stock engine. I can’t help but wonder if the carbon build up would be similar in a stock motor. I typically run valvoline synthetic or Napa synthetic in my Rio. From your post it sounds like the top half of the engine was in pretty good shape for 160k with the exception of the carbon on the valves.
Discussion Starter #7
That was the stock 1.6 from the 2013 Rio. I swapped in a 1.6 turbo (factory) from a forte. So I just had the original na 1.6 out of the car and tore it apart to see what it looked like.
Those chipped valves concerned me, but it ran just fine when I pulled it out.
Thanks for the clarification. So carbon buildup is to be expected on these motors given your experience. Now if someone would post pics of the internals of another 1.6 at approx the same miles where a catch can had been used, we might have some evidence one way or the other about the benefits of using a catch can to help prevent carbon build up.
1 - 8 of 8 Posts
