2009 Kia Sportage EX 142k, 2010 Kia Soul plus 90k
The ABS light comes on and sometimes goes out. Usually is out after car is off for a while. When it is on the ESC Off light comes on, and sometimes the 4wd light, TPS, and the check engine light as well. The code was P0501. I get the impression that these systems can interlink with each other. Car runs great and doesn't seem to be having any difficulties. If I was to start somewhere what would be the best place. Since the ABS seems to be the first problem should I start there? I just bought this and car fax shows it has been maintained.
4wd v6
Any help will be greatly appreciated.
Thank you.
I eventually found out it was the ABS module and it was replaced under a recall.
