1 - 1 of 1 Posts
Hi,
I've been experiencing a problem recently where every time I get gas, for the next day or so, the driver-side sliding door (manual) will only open an inch or so. I'm assuming there is some sort of safety switch in place that prevents the door from opening while you're pumping gas.
Does anyone know where the switch is located? Or if there is another problem that I'm not aware of?
Figured replacing the switch would do the trick.
1 - 1 of 1 Posts
