2009 Kia Rio LX
My daughter just bought an 09 Kia Rio and the turn signals are not operating. Here is a list of symptoms.
1) Turn signals will not operate (FUSE IS GOOD)
2) Hazard operates all except the rear driver signal (FUSE BLOWS WITH OPERATION)
3) Hazard relay has been tested and is good.
4) Multi function switch has been tested and is good.
5) All bulbs are good.
I was trying to fond a wiring schematic so I can start tracing wires, but have been unsuccessful. If any one knows where I can get schematics or a good link for a service manual would be appreciated.
Also if anyone has any ideas of what else to check, I'm all ears.
Thanks in advance
When you say won't work, do you mean not blink? Does the light come on? You may still have a blinker relay, check that as well.
2009 Kia Rio LX
The blinkers worked for a few min today. When I pulled into the garage they were working. Turned the car off and then back on and now not working. When they were working, all lamps worked except the rear driver lamp, (LAMP IS GOOD), both dash indicators worked.
