my 08 spectra front turn single stop working, i changed the bulb and nothing. still didnt work. so i let it be for a while and now the back one wont work either. I changed the bulb and checked the grounds and i can see no breaks in the wiring. any help you can offer i would appreciate
2005 Kia Spectra LX, BMW e34 & e46
Have you used a multimeter to check if you're getting voltage to the bulb socket when the blinker is engaged? Also, your wiring may look good and be intact, however the contacts in the light housing may be shot. With the blinker on, try slightly wiggling the bulb in the socket and see if the bulb lights up. Wear latex/rubber gloves while doing this.
I just had to replace my wiring harness on the rear light housing on my 2005 Spectra. I tried everything- new bulb, bulb grease, etc. Turns out I needed a new socket.
Do some searches on BCM and ETACS in this forum..
They have been failing more and more often.
The turn signal lamps are controlled by the BCM/Etacs
