My '07 Rondo has the door light (red warning light on the lower-left corner of the dashboard) on all the time. I assume one of the door sensors is broken. Unfortunately the indicator only shows that a door is opened; not which one. How do you troubleshoot it? Are OBD trouble codes more specific? I have a rather old OBD scanner; I am not sure if the codes are door-specific.
Thank you,
dudlo
nope, they are not specific.
Try to push every single sensor and see if it works.
Also, you may remove every sensor and disconnect the cable. Although, I am not sure if the sensor is shorted when open or when closed...
Might need to verify.
I do not think the hood will be displayed. Trunk 100% is separate.
see kiatechinfo about details - free service
