I have an 06 Sedona that the driver side sliding door only works manually. I read another thread where someone mentioned the fuel door safety switch. I found a Kia part number, 815404D100, and it's not very expensive. My question is this. Is there anyone that has replaced this switch and it fix their problem and if so how do you get to it? Is it something that I might be able to take out and clean contacts? Any info would be greatly appreciated.
I am unable to check right now, but I think the switch is held in by 2 bolts. If not you take the trim panel off on the inside of the car most likely.
How switch operates:
When fuel filler door is OPEN, it tells controller for door to NOT OPEN THE DOOR.
Be grateful you didn't have a situation the door opened while getting fuel.
The door will come back, damage the fuel filler door and depending on how it interacts with the gas pump handle as the door slides back it will damage the wheel arch.
Got one right now like that, damage around $1,300.
Malfunction occurred while in warranty - hence mfg is responsible is my position on the matter.
As with say a fuel line that was improperly crimped and let loose spraying fuel, that fuel igniting and damages the car if the event occurred while car was in warranty mfg should be required to pay to restore customers care... Not just replace the fuel line itself.
