I had intermittant radio reception, especially on AM, and discovered that the antenna connection located under the passenger rear pillar cover had come unsnapped from the antenna module. You can get to this connector by removing the SRS emblem in the C pillar cover, then remove the phillips screw under the emblem. Next pull on the top of the plastic cover and it will release and reveal the antenna wiring and the air bag inflation device. After checking the connections, just reverse the procedure and reassemble the pillar cover and reattach with the screw.
Can these modules go bad? I just checked my 07 optima and all the connections were ok. I can only get 4 FM stations when another family car can get a lot more.
