09 kia spectra ex,'11 Dodge Journey AWD,04 Chry. T&C, 08 Pontiac G6 gt
Wow, that long with an open fuel line? Diesel fuel will go bad over that stretch of time along with the filter. I'd suggest a NEW filter and remove fill cap and back air press blow the line back to the tank. As according to what I understand from member gee6 that there is no "low press. lift pump in the tank on your year. This could explain the sometimes fuel and other times only a little flow. Better yet would be to drain the fuel tank check the inside of it for debris as gee6 talked of, repair as required and use FRESH diesel fuel.
I was under the impression that this was a short duration timewise motor swap. Not such a long time all apart.
Good Luck and we are here to help!
