The factory alarm system seems to have lost it's mind. It will randomly decided to act like the car is being broken into, even when locked and unlocked with the keyfob, and will not respond to the reset instructions in the manual. Pulling the fuse no longer works either. I can pull it for an hour or more, put it back and the alarm will still act like it needs to be reset.
I've tried:
Pulling the fuse for over an hour
Replacing the battery in the fob (that was my first thought)
Making sure all of the doors, hatch and window and hood are shut tightly
The next thing on the list is disconnecting the negative side of the battery.
If that doesn't work, what can I try next? I'm really close to digging up the wiring diagram for the alarm and ignition, cutting the alarm out and reconnecting the ignition!
I've tried:
