Hey guys,
I have an 04 Kia Rio with an automatic transmission. I just did an engine swap in it, and when you turn the key you get.....nothing. The only thing I get is a clicking noise that is coming from a box (some sort of BCM i'm guessing) that is bolted to the floor below the radio/hvac stuff. While doing the engine swap my dad has being taking the interior out of the car, so I am wondering if something that affects the car starting could have gotten disconnected. Where is the neutral safety switch located on these cars? Any ideas guys? I don't know the history of the car but is was supposedly running before the engine went south. The only fuse I see that is marked 'start' is good. I am thinking the ignition switch is working because I do not get a clicking from the box I described earlier until I attempt to start the car, I am thinking if this was bad I would not get anything anywhere.
*also I am getting power at the starter because I made the mistake of trying to tighten one of the nuts on the stater while the battery was hooked up...kinda made a spark
