How do I remove the panel under the steering wheel on an '04 Optima? I removed the two screws at the bottom as well as the screw inside the cruise/dimmer switch panel, but the under-wheel panel is still stuck up near the ignition... help?
A ahfrederick 2217 posts · Joined 2005 Add to quote Only show this user #2 · Oct 21, 2005 ouch.. sorry man hopefully someone will be able to help you on this issue.. ANYONE?
K kdegraaf Discussion starter 8 posts · Joined 2005 Add to quote Only show this user #3 · Oct 21, 2005 Nevermind.
