1 - 7 of 7 Posts
2004 Kia Sorento
Hello, I'm in a bind and could really use some help. I got a '04 Kia Sorento that I'm supposed to be selling today. But last night i went to start it and it had no power at all, no lights, no door ding, nothing. It has a new battery and battery terminal clamps, all connections are clean and looks to be properly grounded, and all fuses are good. Now after messing with it for some time I found I can get power if I run a wire from + on the battery to + terminal in front of the fuse box it'll start, run, everything works??? I can't sell it like this, If I permanently hook up a line it doesn't start just pops and goes dead again.
I went and removed and tested the starter, cleaned off all the connections to that and the alternator it's all good. I'm thinking bad ground maybe but I can't seem to find it anywhere. So I followed the little red wire from the fuse box terminal all the way to what I think is a CDI mounted behind the rear passenger tire. I can order a new one for $60 but it'll take 2 weeks to get here. So I called my local KIA dealer they think it might be a $145 sensor that's somewhere under the carpet on the passenger side floor board. But they'll have too first run a $96 diagnostic.
I do not know what to do I am no mechanic and in the last few months I've replaced the rear axle, transfer case, all the brake pads and lines, 2 calipers, battery, both battery terminals and now this. I just want it gone, please help!
Drives : Nissan NV200 Flies : Rans S6ES
But last night i went to start it and it had no power at all...I found I can get power if I run a wire from + on the battery to + terminal in front of the fuse box...I'm thinking bad ground maybe but I can't seem to find it anywhere.
You've already confirmed what the fault is, and it's not a bad ground. I think it's unlikely to be a $145 sensor under the carpet either. Your jump wire test tells us there is a high resistance in the circuit between the battery and the fusebox.
Did you check the main fuse in the fuse box in the engine compartment?
115259
2004 Kia Sorento
Dude you're the man thank you That was a tore it all apart cleaned it all scraped it all, works great!!!
1 - 7 of 7 Posts
