My 03 Spectra was running great never had a problem, Washed the motor at the car was and now it is miss firing, has carbon build up on two spark plugs, runs ruff at idle and better at higher rpms, cranks really slow at times like it gets stuck and then it gives, will start with a little gas peddle but not a lot? any help is appreciated, cleaned the injectors, tested the TPS, changed fuel filter checked all connections and fuses???
