So my 2003 spectra is throwing a couple codes,
P0325
P0304
Check engine light just came on a few days ago, I believe the P0304 triggered the engine light because the car has had the P0325 code for a while.
Symptoms:
Rough idle @ startup (misfiring I assume)
Hesitates for a few seconds when first trying to accelerate (still misfiring I think), then runs fine
Seems to run fine after the initial rough start up and hesitations
It's weird because it runs really rough when I first start the car, and hesitates for a few seconds when I first hit the gas pedal to accelerate. But after I get on the road, it seems to run fine.
Codes are for a Cylinder #4 misfire & Knock Sensor 1 circuit fault
Any suggestions? Spark plugs are new, haven't changed the wires though. Should I get a new knock sensor? Not sure how bad this is for the car, my other car has a bad wheel bearing, my luck has not been great lately
Thanks for any help guys, would be greatly appreciated.
P0325
P0304
Symptoms:
