I have an 03 with about 72,000 miles. it started to stumble and shut down. i checked the code it was #5 cyl miss fire. so i changed the spark plugs,wires and #5 coil. it now will run and rev up. but has a miss when engine is reved up and the same code #5 cyl miss fire. any help! please
You need to have the ICV checked and your compression also. You may have dropped a screw in the intake and bent a valve. When you replaced the plug you fixed the ignition part but I am suspecting compression issues.
doesnt sound like there is a bent valve. only misses when throttle is slightly pressed only a few rpms above idle and en engine light doesnt come on every time. were is the icv located. possible loose screw?
I have never heard a bent valve. Get an actual compression number and let us know what it is.
