2001 Kia Sportage 4x4, 1995 Jeep Wangler
Need to replace the fuel tank skid plate/shield. Could not find one with any discount part stores. I guess will have to go to dealer. Does the skid plate/shield hold the gas tank? Will gas tank drop once the skid plate is removed?
thanks to anyone that comments
Greetings,
Yes, you will have to go to the dealer for replacement part, or PM cobra259 here on the forum .. http://www.kia-forums.com/95332-cobra259.html
If not leaking or smelling fuel, and it is -just- the shield, you can (unbolt) the shield from the fuel tank after dropping the fuel tank - just leave it off, the shield/batting trap moisture -> and corrode the tank..
This link: (thanks DavesSpectra)
https://drive.google.com/folderview?id=0B-YuNuTyh57XUXZKRnlLMV9sMTA&usp=sharing
Group00.PDF is table of contents,
Group22-1.PDF, Looking for: "Fuel System 22-13 / Fuel Tank" (page 13) details the removal procedure for the fuel tank / shield. Once the tank is dropped/removed, you can (unbolt) the shield from the tank assembly.
** Important: If dropping the fuel tank, -make sure- to loosen/break/remove all hose connections, including the fuel filler hose -at the tank-, to avoid pulling hoses down / stressing the filler neck assembly .. **
Regards,
GottaCruise
