1 - 7 of 7 Posts
I have a 02 Kia Spectra that just will not start it started bogging down real bad 4 a few hours then when I got to my destination it wouldn't fire up did everything i could so far but im no mechanic please i need ideas
CEL been on before this happened???Did you check for fuel dilution in the oil(total gas flooding? Checked the coolant level to see if it's full or empty(blown head gasket)? What is "everything you could" besides keep cranking on the key?
  • Like
Reactions: Lou O.
99 Kia Elan 1.8L, 17 Ford Edge Sport 2.7L V6, 15 Mustang 3.7L V6, 2013 BMW K1600 GTL
So what is everything?
FYI, without putting the effort in to describe what you've done, you'll get folks suggesting things and you responding "done that".
Do you have fuel in the tank? Have you performed routine preventative maintenance as spelled out in the owner's manual? Miles on vehicle? Vehicle is 17 years old, so it could be many things, especially if your over 100K miles. Help us help you by providing additional information. Thanks!
  • Like
Reactions: MIA KIA 09
It looks like the Forum is back into rash of these kinds of postings. What really gets me though are the ones that obviously have gotten codes read and too lazy to look up the code(s) diagnostic steps needed for effecting the needed repair, or post here with the general description and not the actual code number. Google search of Code number is VERY EASY to do. and most results sites give the steps of what diagnosis needs to be done.
If you are NOT getting any exhaust pressure or intake suction...you have some kind of major internal problem. Not a computer problem to be dealing with yet. GOOD diagnostic (going step by step) will go a long way to find the problem. Did you do a compression test on each cylinder?
Keep it polite, and take care of the below before making another post.
eg.
USA
1 - 7 of 7 Posts
