My car overheats after driving it about 30 mins of less and then the A/C will blow hot air. I have noticed the A/C fan that fits outside the radiator stops working when the car starts to overheat. The other fan on the driverside runs and works like it should, but not enough to cool the system alone.
I have worked on cars, but not on Kia. I can change the brake pads which were the easy, the beat I have ever done and didn't get dirty.
thanks.
Similar problem happened to me. Check your fuse box and under the "cooling" part of the fuse box your fuse might be blown. If it is, replace the fuse and drive for a few minutes. Open the box again and see if the fuse has blown again. If it has I believe it is a seized motor fan. This happened to me and the car would overheat if it was in stop and go traffic.
