Nitrogen In Tires - Page 3 - Kia Forum
 1Likes
post #21 of 33 (permalink) Old 08-26-2012, 07:38 PM
PLP
PLP's Avatar
Quoted: 330 Post(s)
weird... if you pump them on cold, they should be OK.
The only advice would be to adjust pressure on cold - the time when you get TPMS.
USA - paid, repair manual
Europe - paid, repair manual
PLP is offline
post #22 of 33 (permalink) Old 08-28-2012, 08:55 AM
Premium Member
1fastkia's Avatar
Quoted: 17 Post(s)
I have filled them before going to bed, right when I get up, right after I leave, after I get to work, after work, ect. Nothing helps. I would think of a leak, but it never happens dead in the summer when temps stay above 50-60 at night.
Even when I work 12 hrs during the day and it sits that whole time, I don't get the tpms. Its only overnight. Its not sitting thats doing it, so I assumed it was temps leading to it. It does look soft in the morning.. Yet you arrive at work and light is off, tire looks fine again. How, I don;t have a clue. its only 7 miles to work now.
They have done this since day 1 of owning the car. Dealer says its normal for that tire.
1987 Mazda RX-7 GLX
The Old
1fastkia is offline
post #23 of 33 (permalink) Old 08-28-2012, 09:49 PM
PLP
PLP's Avatar
Quoted: 330 Post(s)
hmmm...
sorry for saying that, but is it TPMS light or low pressure light?
I get TPMS "error" light from time to time - no CEL, no codes - no way to tell why. For sure not pressure issue.
So, since you get a low pressure light, check the pressure. In all of them. Add to the spec and you should be fine.
In Rondo, 225/50x17 I need to add a few PSI before winter. On some colder times I add even a few more. When summer comes back, I need to release some air... Normal condition.
FOR sure I would not drive when the TPMS comes on. It means that instead of 32 PSI you got 25? Less?
PLP is offline
post #24 of 33 (permalink) Old 08-29-2012, 08:36 AM
Drives: Cerato
This topic arises from time to time just to see who was asleep during elementary science classes. As the man said, 'snake oil'.
It's worthwhile adjusting 'cold' pressure depending on ambient temperature. About 1 PSI for every 10C difference in temperature. Tyres usually run 20C hotter on the road.
Dr Bob is offline
post #25 of 33 (permalink) Old 09-10-2016, 11:08 AM
Drives: 2016 Rio SX Hatch
Quoted: 58 Post(s)
Hyperbole and facts aside for a moment........
I live in Canada, where in my province it goes from as hot as 100 degrees in the summer, to as low as -40 in the winter. All temps quoted in Fahrenheit.
Commonly our winters are in the 0 to -20 range.....going down to -40 for weeks at times. I started putting nitro in my tires 6-7 years ago, and I have never had a slow leak again.
Before, when the winter weather changed dramatically in 24 hours (a 30 degree swing in temps is not unusual) it was not uncommon for the odd tire to be soft and require some air. This has not happened since.
Now, you can say that maybe remounting it with some rim goo might have been all that was required, who knows, but in my particular climate, driving only new cars with OEM tires, having nitro made a difference.
And no, I do not own a tire shop that sells nitro.
Rio Taxi is offline
post #26 of 33 (permalink) Old 09-10-2016, 11:21 AM
Drives: 2017 AWD Sportage SX - Black / Beige
Quoted: 624 Post(s)
you've been putting "nitro" in your tires, as you put it, since day one, 78% of everything you put in there was "nitro".
N2 it is not the reason you aren't getting flats etc regardless of the ambient temperature. You're just lucky, which is a far better explanation that using pure N2 in your tires, for your performance over the past 6-7 years.
And to actually PAY extra money for this snake oil....well one born every minute as the saying goes i guess.
Sloppy is offline
post #27 of 33 (permalink) Old 09-11-2016, 05:05 PM
Quoted: 58 Post(s)
I fully realize that 78 % or whatever of oxygen is comprised of nitrogen. They started putting it in certain aircraft due to the ambient temperatures encountered when moving thru thru different speed and altitude envelopes, because that 22% must have made a difference somehow. The outside air temps at 40,000 feet are similar to our extreme winters here, and as we chill and thaw, our temps can fluctuate dramatically.
Not only have slow leaks stopped, but TPMS lights have also stopped going off as well. Most TPMS systems light up if there is a .5 PSI variance.......to me, pure nitrogen reacts differently than oxygen. Obviously, something is happening here and I am no chemist, but if it works for me...........so be it.
YMMV in a different climate.
Rio Taxi is offline
post #28 of 33 (permalink) Old 10-02-2017, 07:55 AM
Drives: 2017 Sedona LX+
Quoted: 18 Post(s)
As others may have said in this thread, nitrogen in the tires is to keep the tire pressure more stable in a wider temperature range. That's it.
A lot of top speed racecars and exotics have nitrogen in the tires because of the high temps generated from their higher tested top speeds (higher speed, higher tire temp, higher tire pressure). I don't really think its worth the extra cost, but if your shop does it for free, sure go for it.
2017 Kia Sedona LX
rougeben83 is offline
post #29 of 33 (permalink) Old 10-06-2017, 02:04 PM
Drives: Kia Soul 2014
I just had a flat tire that the repair shop plugged and they filled the tire with regular, not nitrogen.
So I guess it varies by who is selling what.
DMICPA1075! is offline
post #30 of 33 (permalink) Old 01-14-2018, 09:31 AM
SoNic67's Avatar
Drives: Kia Soul!, 2011
Quoted: 38 Post(s)
Physics 101: The actual difference is made by the water/moisture content in the air inside the tire.
Some shops run a de-humidification device (called commercially "Compressed Air Dryer") after their compressors, and that puts the air in the same category as the nitrogen - low to no moisture. But it costs money to buy one and uses extra electricity to run.
The problem with the water/moisture vapors is that, at low temperatures, will partially condensate (and eventual fully condensate) inside the tire. That is called a "Dew point temperature".
The pressure will drop because liquid/solid water takes less volume than vapors of water. There are even diagrams that show the relation between water partial vapor pressure and temperature - they are used in HVAC world.
In regenerative desiccant dryers of the heatless variety, at 100 psig, such a dryer will usually have a dew point rating of minus 40 degrees Fahrenheit, though sometimes the dew point can drop as low as minus 100 degrees.
SoNic67 is offline
  Kia Forum > Technical > Suspension, Wheels and Tires
Need to purchase my first set of tires and brake pads any recommendations and advice? OpenDoors14 Suspension, Wheels and Tires 3 05-20-2018 06:24 AM
★ Winter tires with steel rims and TPMS. Warranty PLP Parts For Sale / Trade 0 10-06-2016 11:45 AM
2011 replacement tires worn at 30k, steering vibrates above 75 sorento11 2011 - 2013 (XM) Sorento Forum 4 09-14-2015 08:44 AM
New Tires Review smuook Kia Mohave & Borrego 10 09-24-2009 03:56 AM
Nitrogen filled tires... Shadow_Grey 2003-2010 Sorento Forum 5 03-11-2008 04:30 PM
