New Wheels And Tires - Page 2 - Kia Forum
post #11 of 24 (permalink) Old 02-01-2006, 11:07 AM Thread Starter
rdmnster's Avatar
Drives: 2005 Kia Spectra5
I dont think 40psi will be detrimental. The max pressure on the sidewall is 50psi at 1357 pounds, but I will double check with Yokohama. Thanks
Alex
His; '05 Spectra5
Hers; '05 Sedona EX
rdmnster is offline
post #12 of 24 (permalink) Old 02-01-2006, 11:15 AM
Premium Member
1fastkia's Avatar
Quoted: 17 Post(s)
My 205/40/17 toyo proxy fz-4 tires call for 35psi. Ive never seen a tire for a car with 45 series or less sidewalls call for any more than 35 psi. it would just be to hard on the sidewall....... the sidewalls on a 40 series tire are lucky to be 2 inches high off the rim... it would be hitting bumps like a rock... also handling would go down the drain, and be lucky if you hit a bump with 50 psi and not blow the tire out..
1987 Mazda RX-7 GLX
The Old
1fastkia is offline
post #13 of 24 (permalink) Old 02-01-2006, 11:15 AM Thread Starter
rdmnster's Avatar
04Amanti, I will pull off the fronts again today. I am getting vibrations some times and not others at the same speed. For example when I am doing 50mph it'll be nice and smoth then the vibrations will start and then go away.
Alex
His; '05 Spectra5
Hers; '05 Sedona EX
rdmnster is offline
post #14 of 24 (permalink) Old 02-01-2006, 11:18 AM
Premium Member
1fastkia's Avatar
Quoted: 17 Post(s)
also dont forget the sport tires are made of a much harder compound than a regular tire . with the hard compound and high or low tire preasure will wear in half the time if you had correct preasure.
1987 Mazda RX-7 GLX
The Old
1fastkia is offline
post #15 of 24 (permalink) Old 02-01-2006, 12:17 PM
04Amanti's Avatar
Drives: 2004 Kia Amanti
My 275/45/20 Kumho Ecsta STX tires list a max tire pressure of 51PSI cold...
My 245/45/18 General Exclaim UHP tires also list a 51PSI max pressure....
35 psi seems low for a low profile tire...
An underinflated tire will generate much more heat (and wear) then one inflated to spec and will leave you with MORE of a chance of a blowout.
A fully inflated tire will outhandle an underinflated tire any day and all day long.
When you inflate/air up tires, you should do so when they are cold. I inflate all my tires to 5psi under max tire pressure to allow for the 3-4 psi increase in pressure when they heat up.
I have run all my cars for years and many thousands of miles at near max-psi. Absolutely no uneven wear whatsoever and many of the sets have lasted over the warranteed mileage span.
'04 Kia Amanti - Pearl White w/Leather Package
Mobil 1 / 20% Tint / 18" Chrome Wheels / Opirus Grille / Class II Trailer Hitch/
04Amanti is offline
post #16 of 24 (permalink) Old 02-01-2006, 12:19 PM
04Amanti's Avatar
That is actually often not the case. Ultra high performance tires (especially summer tires) are mostly made with softer rubber compounds. Hence the grippier nature of the tires and the lower treadwear rating.
04Amanti is offline
post #17 of 24 (permalink) Old 02-01-2006, 12:24 PM
04Amanti's Avatar
You may want to try to find a tire shop that will do "roadforce balancing". They will have a special tire balancing machine that will balance tires simulating as if they were mounted on your car under load and at higher speed. This gives a much better balance than standard tire balancing machines. It is pricey though.
04Amanti is offline
post #18 of 24 (permalink) Old 02-01-2006, 05:09 PM Thread Starter
rdmnster's Avatar
Can you tell me if "road force" balancing is the same as "static" balancing? Also do you recommend a national tire chain or maybe a specialty type shop, ie racing?
Alex
His; '05 Spectra5
Hers; '05 Sedona EX
rdmnster is offline
post #19 of 24 (permalink) Old 02-01-2006, 05:55 PM
04Amanti's Avatar
Roadforce balancing is different from static balancing. Static balancing is how most passenger/truck tires are balanced.
Go to: http://www.tirerack.com/
At the bottom right of the page, look under "Getting It Installed". There is a place to enter your zip code. It will then list the tire installers in your area, including those who are roadforce balance capable.
I would not recommend a "racing shop" unless it is known to be reputable.
04Amanti is offline
post #20 of 24 (permalink) Old 02-01-2006, 07:26 PM Thread Starter
rdmnster's Avatar
Thanks for the info, I am headed to a Goodyear shop about a mile from my house tomorrow and we shall see how the roadforce balance works.
Alex
His; '05 Spectra5
Hers; '05 Sedona EX
rdmnster is offline
  Kia Forum > Technical > Suspension, Wheels and Tires
Southern California: 2016 Kia Sorento OEM 17" Wheels & Tires - only 857 miles VelyC Parts For Sale / Trade 2 01-07-2016 04:31 AM
Spectra 5 Wheels & Tires Atomicbeaker Suspension, Wheels and Tires 2 11-21-2007 11:13 AM
