Tires - Kia Forum
 1Likes
post #1 of 15 (permalink) Old 02-20-2018, 08:03 AM Thread Starter
Drives: 2012 Sorento EX-V6 Luxury
Quoted: 25 Post(s)
Tires
I purchased a set of Nokian WRG3 tires on January 10, 2017 at 194299km (12732miles) from KalTire. Yesterday, when my Sorento was in for service it was noticed that I had separation on all four, severe on the rears & lesser on the fronts. The mileage was 238,808km (148388 miles).
There is plenty of warranty left on these tires. My challenge is the tires were purchased in Canada & I am currently snowbirding in Arizona. I'll contact my Canadian dealer this morning to see if they can help me out with getting a warranty rebate with Discount Tire.
Eh!
2012 KIA Sorento EX-V6 Luxury
geeksrus is offline
post #2 of 15 (permalink) Old 02-23-2018, 08:13 AM Thread Starter
Quoted: 25 Post(s)
Update: On Tuesday (20th) I had Discount Tire (Nokian dealer) check the tires & they indicated it was Cupping & not separation. They recommended that I do a tire rotation.
Yesterday (22nd) I had them do the tire rotation. On the way home, 25 miles, the amount of humming was much less. When I return to Alberta I'll have a few words with my local tire dealer.
BTW: I would appreciate if some one would give my an education of tire cupping. Not too technical please.
Eh!
geeksrus is offline
post #3 of 15 (permalink) Old 02-23-2018, 08:24 AM
Quoted: 715 Post(s)
Cupping usually due to bad shock absorbers and poor balancing.
https://www.popularmechanics.com/car...r-car/?slide=3
ron1004 is offline
post #4 of 15 (permalink) Old 02-23-2018, 08:27 AM
Quoted: 364 Post(s)
Was just going to ask what you meant by "separation". Cupping is a term used for a wear pattern of the tire that looks like someone has "scooped" out sections of tread in a pattern around the the diameter of the tire. AWD/ 4WD are known to exhibit this pattern and is why tire rotation is so important to be done. It can also be caused by worn out struts/shocks and any number of suspension wear concerns. A good tech can even determine if the tires inner cord belts has shifted/broken and show this type of pattern.
Hope this was not TOO TECHNICAL...
MIA KIA 09 is offline
post #5 of 15 (permalink) Old 02-23-2018, 09:15 AM
Quoted: 715 Post(s)
Would be good to see pictures.
ron1004 is offline
post #6 of 15 (permalink) Old 02-23-2018, 10:06 AM
Quoted: 364 Post(s)
LOL...I spent most of my life as an auto tech, and NOT a computer geek(Commodore 64 came out while I had graduated high school already). I struggle to post pic's much less do links from other sources. BUT both our responses in this thread are on the same track! Unless the OP has had struts/shocks replaced already, by mileage posted is probably way overdue.
post #7 of 15 (permalink) Old 02-23-2018, 10:13 AM
Quoted: 715 Post(s)
NO, I meant the OP to post pics so that we can understand his problem.
MIA KIA 09 likes this.
ron1004 is offline
post #8 of 15 (permalink) Old 02-24-2018, 08:25 AM Thread Starter
Quoted: 25 Post(s)
Thanks for this... not too technical for me the I replaced the shocks & struts last February at 235,520km (146,345m).
Discount Tire said that the cupping was a result of the tires being All-Weather (almost as rugged as Snow Tires) and that using them in Arizona's hot weather is the most probable cause of the cupping.
When I return to Alberta mid-April I'll bring the vehicle to the tire dealer where I had purchased them to see what these guys say. Not that I fully trust them.
Eh!
geeksrus is offline
post #9 of 15 (permalink) Old 02-24-2018, 09:36 AM
Quoted: 364 Post(s)
So with roughly 21,000 miles,you just had the tires rotated? With an AWD or 4wd, they should be rotated at least every 8 - 10 thousand miles. But glad to hear with as many miles you have on yours (and sounds like good service from it)that you did have the struts/shocks replaced!..
Not so sure of climate temp change being the cause of this, but I personally know of folks having tire troubles when traveling to such warmer areas. Maybe enhanced by not having tires rotated sooner and already showing some of this wear before you left for "snowbirding".
post #10 of 15 (permalink) Old 02-25-2018, 07:47 AM Thread Starter
Quoted: 25 Post(s)
How did you figure out that I JUST HAD THE TIRES ROTATED????? You never inquired about when they were last rotated?
The fact is I take very good care of my vehicles as per the service manual. I rotate at least every 12,000km or 6 months. So don't lecture me on how I am not caring for my Sorento.
Eh!
geeksrus is offline
  Kia Forum > Technical > Suspension, Wheels and Tires
Need to purchase my first set of tires and brake pads any recommendations and advice? OpenDoors14 Suspension, Wheels and Tires 4 06-01-2019 12:51 AM
Cupped tires Jeff10236 Suspension, Wheels and Tires 2 05-20-2018 08:39 AM
★ Winter tires with steel rims and TPMS. Warranty PLP Parts For Sale / Trade 0 10-06-2016 11:45 AM
2011 replacement tires worn at 30k, steering vibrates above 75 sorento11 2011 - 2013 (XM) Sorento Forum 4 09-14-2015 08:44 AM
New Tires Review smuook Kia Mohave & Borrego 10 09-24-2009 03:56 AM
