Most Error Codes - Kia Forum
post #1 of 1 (permalink) Old 06-30-2009, 02:06 PM Thread Starter
Most Error Codes
First off these came from haynes and also from sk forums.
P0030 HO2S Heater Control Circuit(Bank1, Sensor1)
P0031 HO2S Heater Circuit Low (Bank 1, Sensor 1)
P0032 HO2S Heater Circuit High (Bank 1, Sensor 1)
P0036 HO2S Heater Control Circuit(Bank1, Sensor 2)
P0037 HO2S Heater Circuit Low (Bank 1, Sensor 2)
P0038 HO2S Heater Circuit High (Bank 1, Sensor 2)
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0112 Intake Air Temperature Circuit Low Input
P0113 Intake Air Temperature Circuit High Input
P0116 Engine Coolant Temperature Sensor Circuit Range/Performance Problem
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0121 Throttle Position Sensor Circuit Range/Performance Problem
P0122 Throttle Position Sensor Circuit Low Input
P0123 Throttle Position Sensor Circuit High Input
P0125 Insufficient Coolant Temperature For Closed Loop Fuel Control
P0128 Coolant Thermostat (Coolant Temp. below Thermostat Regulating Temp.)
P0130 HO2S Circuit Malfunction (Bank1, Sensor 1 )
General Information Scantool Diagnostics Monitor Scantool Data Inspection/Repair W/Harness Inspection Component Inspection Verification of Vehicle Repair P0131 HO2S Circuit Low Input (Bank 1, Sensor 1)
P0132 HO2S Circuit High Input (Bank 1, Sensor 1)
P0133 HO2S Circuit Slow Response (Bank 1, Sensor 1)
P0134 HO2S Circuit No Activity Detected (Bank 1, Sensor 1)
P0136 HO2S Circuit Malfunction (Bank 1, Sensor 2)
P0137 HO2S Circuit Low Input (Bank 1, Sensor 2)
P0138 HO2S Circuit High Input (Bank 1, Sensor 2)
P0139 HO2S Circuit Slow Response (Bank 1, Sensor 2)
P0140 HO2S Circuit No Activity Detected (Bank 1, Sensor 2)
P0171 Fuel System Too Lean(Bank 1)
P0172 Fuel System Too Rich(Bank 1)
P0230 Fuel Pump Circuit Malfunction
P0261 Cylinder 1 - Injector Circuit Low
P0262 Cylinder 1 - Injector Circuit High
P0264 Cylinder 2 - Injector Circuit Low
P0265 Cylinder 2 - Injector Circuit High
P0267 Cylinder 3 - Injector Circuit Low
P0268 Cylinder 3 - Injector Circuit High
P0270 Cylinder 4 - Injector Circuit Low
P0271 Cylinder 4 - Injector Circuit High
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 - Misfire detected
P0302 Cylinder 2 - Misfire detected
P0303 Cylinder 3 - Misfire detected
P0304 Cylinder 4 - Misfire detected
P0325 Knock Sensor Circuit Malfunction (Bank 1)
P0335 Crankshaft Position Sensor Circuit Malfunction
P0340 Camshaft Position Sensor Circuit Malfunction
P0420 Catalyst System Efficiency below Threshold (Bank 1)
P0441 Evap. Emission System Incorrect Purge Flow
P0442 Evap. Emission System - Leak detected (small leak)
P0444 Evap. Emission System - Purge Ctrl. Valve Circuit Open
P0445 Evap. Emission System - Purge Ctrl. Valve Circuit Shorted
P0447 Evap. Emission System - Vent Control Circuit Open
P0448 Evap. Emission System - Vent Control Circuit Shorted
P0451 Evap. Emission System - Pressure Sensor Range / Performance
P0452 Evap. Emission System - Pressure Sensor Low Input
P0453 Evap. Emission System - Pressure Sensor High Input
P0454 Evap. Emission System - Pressure Sensor Intermittent
P0455 Evap. Emission System - Leak detected(Large leak)
P0456 Evap. Emission System - Leak Detected (Very Small Leak)
P0501 Vehicle Speed Sensor Range/Performance
P0506 Idle Control System - RPM Lower than Expected
P0507 Idle Control System - RPM Higher than Expected
P0560 System Voltage malfunction
P0562 System Voltage Low
P0563 System Voltage High
P0605 Internal Control Module Read Only Memory(ROM) Error
P0650 Malfunction Indicator Lamp(MIL) Control Circuit Malfunction
P1166 HO2S System - Lambda Controller at the Limit (Bank 1)
P1505 Idle Charge Actuator Signal Low of Coil #1
P1506 Idle Charge Actuator Signal High of Coil #1
P1507 Idle Charge Actuator Signal Low of Coil #2
P1508 Idle Charge Actuator Signal High of Coil #2
P1529 TCU Request for MIL On
P1586 MT/AT Encoding Error
P1693 MIL Request Circuit Malfunction
Rio [BC] > 2004 > A/T > 1.6
P0601 Momory Check Sum Error
P0604 TCM Ram Error
P0707 Transaxle Range Switch - Low Input
P0708 Transaxle Range Switch - High Input
P0711 Transaxle Fluid Temperature Sensor Rationality
P0712 Fluid(Oil) Temperature Sensor Circuit - Low
P0713 Fluid(Oil) Temperature Sensor Circuit - High
P0716 Input Speed Sensor Range/Performance
P0717 Input Speed Sensor Circuit - No Signal
P0726 Engine Speed Input Sensor Range/Performance
P0727 Engine Speed Signal Invalid
P0731 Gear 1 Incorrect Ratio
P0732 Gear 2 Incorrect Ratio
P0733 Gear 3 Incorrect Ratio
P0734 Gear 4 Incorrect Ratio
P0741 Torque Converter Clutch Circuit - Stuck off
P0742 Torque Converter Clutch Circuit - Stuck on
P0743 Torque Converter Clutch Circuit - Electrical
P0748 Pressure Control Solenoid Valve A - Electrical
P0753 Shift Solenoid A Circuit Malfunction
P0758 Shift Solenoid B Circuit Malfunction
P0763 Shift Solenoid C Circuit Malfunction
P1121 Throttle Position Sensor Signal Invalid
P1500 Vehicle Speed Sensor - Open or Short (GND)
Rio [BC] > 2004 > ABS > MANDO
C1101 Battery voltage over volt
C1102 Battery voltage low volt
C1200 Wheel Speed Sensor Front-LH Open/Short
C1201 Wheel Speed Sensor Front-LH Range/Performance/Intermittent
C1202 Wheel Speed Sensor Front-LH Invalid/No Signal
C1203 Wheel Speed Sensor Front-RH Open/Short
C1204 Wheel Speed Sensor Front-RH Range/Performance/Intermittent
C1205 Wheel Speed Sensor Front-RH Invalid/No Signal
C1206 Wheel Speed Sensor Rear-LH Open/Short
C1207 Wheel Speed Sensor Rear-LH Range/Performance/Intermittent
C1208 Wheel Speed Sensor Rear-LH Invalid/No Signal
C1209 Wheel Speed Sensor Rear-RH Open/Short
C1210 Wheel Speed Sensor Rear-RH Range/Performance/Intermittent
C1211 Wheel Speed Sensor Rear-RH Invalid/No Signal
C1604 ECU Hardware Error
C2112 Valve Relay Error
C2402 Motor - Electrical
Rio [BC] > 2004 > A/BAG > TRW
01 ACU Fault
02 ACU Fault
03 ACU Fault
10 ACU Fault
11 ACU Fault
12 ACU Fault
13 ACU Fault
14 ACU Fault
15 ACU Fault
18 ACU Fault
19 ACU Fault
20 ACU Fault
21 ACU Fault
22 ACU Fault
23 ACU Fault
24 ACU Fault
25 ACU Fault
26 ACU Fault
27 ACU Fault
28 ACU Fault
29 ACU Fault
31 ACU Fault
32 ACU Fault
33 Power Supply Low
34 Power Supply High
35 Warning Light Short
36 Warning Light Open
53 Driver Module Short to ground
54 Driver Module Short to battery
55 Driver Module Short
56 Driver Module Open
57 Passenger Module Short to ground
58 Passenger Module Short to battery
59 Passenger Module Short
60 Passenger Module Open
61 Driver pretensioner short to ground
62 Driver pretensioner short to battery
63 Driver pretensioner short
64 Driver pretensioner open
65 Passenger pretensioner short to ground
66 Passenger pretensioner short to battery
67 Passenger pretensioner short
68 Passenger pretensioner open
77 ACU Inconsistency(ex-clusive of PA
78 ACU Inconsistency(ex-clusive of PA
79 ACU Inconsistency(ex-clusive of PA
80 ACU Inconsistency(ex-clusive of PA
cwalsh_00 is offline
  Kia Forum > KIA Models > Kia Cerato, Shuma & Spectra Forum > Shuma & Spectra (1997-2003)
