Is my transmission dead? - Kia Forum
post #1 of 4 (permalink) Old 04-25-2014, 01:55 PM Thread Starter
Bought my 16 year old a 2002 kia spectra. His engine light came on and he didn't tell me until 3 days later when the car wouldn't move. He had run out of transmission fluid. Now that we refilled it we have no drive. Low 2 works and you can switch over to drive once you pick up speed. We have 3 codes. PO741, P1529, and PO732. Any ideas? I'm a single mother with 3 teenage drivers and really can't afford to go to a transmission shop.
[email protected] is offline
post #2 of 4 (permalink) Old 04-25-2014, 02:19 PM
PLP
PLP's Avatar
Quoted: 330 Post(s)
moved to the right section.
Well, it is likely the transmission is damaged.
How much the fluid did you add? Who added the ATF?
Also, what is the colour of the fluid now?
USA - paid, repair manual
Europe - paid, repair manual
PLP is offline
post #3 of 4 (permalink) Old 04-25-2014, 04:03 PM Thread Starter
Almost 3 quarts
My friends husband
Normal color
post #4 of 4 (permalink) Old 04-29-2014, 01:46 PM
PLP
PLP's Avatar
Quoted: 330 Post(s)
3 quarts only? If the tranny was empty it should have taken more than that.
Capacity is around 7-9.
P0732 KIA
Possible causes
- Low transmission fluid level
- Dirty transmission fluid
- Faulty Shift Solenoids
- Shift Solenoids harness is open or shorted
- Shift Solenoids circuit poot electrical connection
- Transmission mechanical problems
- Transmission hydraulic control circuit
Read more: P0732 KIA Second Gear Incorrect Ratio OBDII Engine Light Trouble Code | Engine-Codes.com
P0741 KIA
Possible causes
- Faulty torque converter clutch solenoid valve
- Torque converter clutch solenoid valve harness or connectors
- Torque converter clutch solenoid valve circuit is open or shorted
- Transmission internal mechanical problem
Read more: P0741 KIA Torque Converter Stuck Off OBDII Engine Light Trouble Code | Engine-Codes.com
P1529 KIA
Possible causes
- Check for transmission codes.
Drain refill fluid, maybe will help...
Eventually do fluid flush.
If does not help - tranny rebuild as I doubt this is electrical issue (such as connectors loose or swapped)
PLP is offline
  Kia Forum > KIA Models > Kia Cerato, Shuma & Spectra Forum > Shuma & Spectra (1997-2003)
Kia Sorento EX Automatic Transmission Change Richard Fritz 2011 - 2013 (XM) Sorento Forum 8 08-22-2018 04:32 PM
Here is how to change the Sorento EX 2.4L Automatic Transmission Fluid Richard Fritz Do it Yourself 0 07-29-2018 03:54 PM
2007 Kia Spectra EX Transmission Problems LegionXVI Cerato (2003 - 2008) & Spectra5 (2004) 4 07-25-2017 08:49 AM
Flushing an automatic transmission cmhj2000 Do it Yourself 0 02-12-2008 11:23 AM
Transmission dead after changing screen revray44 1G (2001-2005) Rio 0 06-02-2007 08:34 PM
