Kia Mentor surging and loss of power. - Kia Forum
post #1 of 2 (permalink) Old 03-11-2012, 09:03 PM Thread Starter
I have a 2000 Kia Mentor 1.8lt.. I could be driving along and the car seems to surge, when i stop at the intersection the car has no power when i put the foot down. The car does not stall the engine is still running but there is no power and it seems to do this after it has been surging, shortly after there is a rotten egg smell and it idles rough. This happens after about 15 minutes of driving, then it has its little moment and then its fine again untill the next time....
I am feeling it may be a sensor going off somewhere.
cuddleskia is offline
post #2 of 2 (permalink) Old 03-12-2012, 01:28 AM
Drives: '96 Camry v6 XLE, '00 Camry LE
Quoted: 125 Post(s)
Greetings,
Welcome to the forum.
If the check engine light (CEL) is on - would recommend hooking up an OBDII scanner and getting the trouble (DTC) codes in the engine computer read, that will help to determine the problem..
If the catalytic converter is original to the vehicle: a clogged / blocked cat. converter can make the vehicle "buck" or "surge" also. Given the model year of the vehicle, if the cat. converter is original to the vehicle, that is a possibility also.
You may also want to view posts and/or search over at the Sephia forum here on the site:
2G (1998 - 2001) Sephia - Kia Forum
Regards,
GottaCruise
OBD-II Codes:
GottaCruise is offline
ESC off and sudden lack of throttle response - TPS & ECU - TSB# KT2009042201 sornord Kia Carnival & Sedona 2006+ 86 09-11-2018 06:13 PM
major power loss dbauto 2G (1998 - 2001) Sephia 4 05-18-2017 11:03 PM
Intermittent power loss of radio, digital clock and power sockets Herve Touche 2G (2003-2010) Sportage 2 02-23-2016 05:34 AM
2011 Kia Sorento Power loss, rattling, smoke Plumber Dom 2011 - 2013 (XM) Sorento Forum 2 06-12-2015 08:02 AM
'01, loss of power after hard brake Aaiiee 1G (1993 - 2002) Sportage 7 01-15-2008 09:01 AM
