2002 Kia Mentor clutch get stiff when warm - Kia Forum
post #1 of 2 (permalink) Old 10-19-2011, 02:21 AM Thread Starter
I recently had the clutch replaced on my car, but as the car warms up the clutch seem to get stiffer & slightly spongy.
Now when it running from cold it seem fine until it warms up again.
Any ideas what could cause this problem before i book into a garage.
also does the UK model Kia Mentor have a cable clutch or is it hydraulic?
ste76 is offline
post #2 of 2 (permalink) Old 10-20-2011, 09:59 AM
Drives: '96 Camry v6 XLE, '00 Camry LE
Quoted: 125 Post(s)
I would search over on the Kia Sephia forum for more info on your issue,
on the 2000 Sportage (US Model) here, the clutch is hydraulic, and there is a bleeder screw at the transmission housing to bleed any trapped air out of the line - the clutch is tied into the brake system (uses brake fluid), so the brake fluid reservoir needs to be re-filled, as the clutch line is bled. (When there is air or old fluid in the line, it behaves exactly like you describe..)
Hope the info helps.
OBD-II Codes:
GottaCruise is offline
2002 Kia Spectra Code P0128 ray1103 Shuma & Spectra (1997-2003) 1 08-02-2018 12:10 PM
Kia 2002 Gear 4 Incorrect Ratio (P0734) Tdog6916 1G (2001-2005) Rio 1 08-16-2009 08:40 PM
2002 vs. 2002 rallyguy07 1G (2001-2005) Rio 2 09-19-2008 07:44 PM
Bought Kia Sedona EX 2002 New with 70,000 miles now... wjcheng Kia Carnival & Sedona (2002 - 2005) 8 09-04-2007 03:24 PM
Rio 2002 brake shoes dsha 1G (2001-2005) Rio 2 06-20-2006 12:41 PM
