KIA BESTA - Page 2 - Kia Forum
post #11 of 50 (permalink) Old 10-28-2004, 11:26 AM
I will consider to setup regional Phillipines forum when we have enough members from Phillipines
imported_admin is offline
post #12 of 50 (permalink) Old 10-30-2004, 07:09 PM
m301987e's Avatar
Drives: KIA Besta,KIA CD5,Nissan Langley,Mitsubishi Pajero
Send a message via Yahoo to m301987e
Post
Originally posted by byahero@Oct 25 2004, 12:13 AM
hello everyone! im new here. na-solve ko na recently ang overheat problem ko with my kia besta, except this one, lagi syang nagkukulang ng tubig. any idea out there? tulungan tayo mga tol.....
try checking your water pump. it could have a leak. the shaft seal is always the culprit! it usually leaks when the engine is hot and water pressure is high.
m301987e is offline
post #13 of 50 (permalink) Old 11-03-2004, 10:57 PM
Originally posted by chedarz@Sep 17 2004, 07:02 PM
hello! it's my first time to post here.
we own a 99 model besta. it's been reliable until lately when we started having problem with its transmission. when we back up, the reverse releases. we've gone to several repair shops and they couldn't fix it. a friend who owns the same model said that he experiences the same thing. help!
i had the same problem before until i brought it to petron service shop along fb harisson near dfa. they have a very mechanic there, his name is orly, try bring your besta there, you wont regret. or call or text me 09163662805
byahero is offline
post #14 of 50 (permalink) Old 11-04-2004, 03:04 AM
m301987e's Avatar
Exclamation
Your problem is synchronizing ring trouble. It might be broken. I have an expert mechanic, his name is Arnel and if you want I can assist you. You can text me on 09176286571
m301987e is offline
post #15 of 50 (permalink) Old 11-04-2004, 03:07 AM
m301987e's Avatar
Cool
Originally posted by MA. LUISA R. GARCIA@Oct 15 2004, 10:24 AM
hi! im a new registrant, first time to post.
my view about kia besta van, is that it's a disappointment. (no offense meant to anybody.) most probably because we bought it second hand, and it's a 96 model.
since we had it, about five years ago, we've experienced a whole lot of breakdowns. The aircon was gone after two years, then we had the belt fan replaced at least four times in a month, until it worked, etc., etc. Now we had to replace some shaft and the front windshield (you don't want to know why).
Can you guys give advice or recommend a good and reliable technician. Also, please give suggestions on where i can find a replacement for the broken front windshield.
Thanks a bunch! Mornin!
I had a broken windshield, tinamaan ng kidlat during a thunderstorm! Freak accident. Anyway, I bought my windshield in Banaue, it was P2,500.00! I don't know the price now because it was last year when the freak accident happened.
m301987e is offline
post #16 of 50 (permalink) Old 11-17-2004, 12:06 AM
[ I am a new entrant. Is anybody out there have advise on a transmission having loose stick while engaging the gears. I own a 1996 besta van 2.2 model. Just recently changed the aircon compressor and find everything okay except for the transmission problem which is manageable.
butchi is offline
post #17 of 50 (permalink) Old 11-17-2004, 12:46 AM
m301987e's Avatar
Post
By loose stick, do you mean excessive play of the shifting lever (stick) when on neutral? If that is the case, it is just a worn out fulcrum bushing. Just have it replaced and your problem is gone.
m301987e is offline
post #18 of 50 (permalink) Old 11-28-2004, 10:32 AM
guys, is it good to set up a 2.2 besta 97 model?.. what do you think?.. i need your opinions and suggestions.. please
boknoy is offline
post #19 of 50 (permalink) Old 01-20-2005, 01:26 AM
hello its my first time to post, i read about some problems with overheating i have a 95 2.7 besta although i was not the original owner i got it sometime 97 with about 34kms on it, and so far it reads now 150kms, and although i had problems with the aircon and alternator already parts are relatively cheap from my friend so i am still holding it until i find a pregio maybe. Regarding the over heating problem i also had that same problem and according to my friend if you notice you have an aircon condenser before your radiator at a perpendicular position. One thing to check is is it blowing air down , or up if it is blowing up then when you have the aircon on you are heating up the air before it reaches the radiator, so imagine hot air for the radiator to cool down the water, not that good , best is to have the air blowing down on the air con condeser down the vehicle, minor problem is air starvation for the radiator but if you have your radiator flushed real good and with a good coolant then i think you should be okay, if this still does not work then i guess you can try the brute force of replaceing the radiator with a added row. That i have not done yet so far. Also regarding the air con blower if you have the blower blowing up according to a friend if you do happen to pass a flooded area you have the danger of blowing up and the water sucked in by the radiator which some say is not good specially if the engine is hot imagine a hot engine block getting a immediate cool shower .
beejay168 is offline
post #20 of 50 (permalink) Old 01-20-2005, 01:31 AM
Now to my problems maybe some of you know where i can have my axle fix some mechanics tell me my drive shaft rotation has a relatively large play, they same i have problems inside my axle , the differential gears they say any one know of someone who can and really know how to fix this and not just some couragoeous mechanic who will say thats easy.
Next i have a alternator with vacuum pump but i dont have the screw that connects to the back that has a hollowed center and hole for the oil to flow to a pipe which is connected to the engine again .
thanks and hope you can help me with these.
need parts for Kia Besta GoBesta Philippines 3 12-13-2017 05:52 PM
kia besta wiring diagram! boy69 Other Kia Models 1 12-17-2011 09:58 AM
Besta transmission moye68 Other Kia Models 6 10-14-2008 12:12 PM
kia besta 1998 model syaoran Performance 0 03-11-2008 02:38 AM
kia besta 2.7 unstable idle oschkie Other Kia Models 0 06-16-2007 07:43 PM
