Kia pride 1.3i vibrating in idle rpm - Page 2 - Kia Forum
 12Likes
post #11 of 19 (permalink) Old 12-31-2014, 03:32 PM
Quoted: 684 Post(s)
It sounds like your Idle Speed Control Valve (ISC), or also referred to as Idle Air Control valve (IAC) is not working - it should modulate to maintain the design idle speed regardless of load changes such as headlamps, power steering or AC.
Very often this can be corrected by cleaning the ISC with carburator cleaner, and if that doesn't fix it then it would be best to connect a scanner to it and confirm that the Engine Control Module is sending the correct signal, if it is, then you need a new ISC.
kville kia and xagrox like this.
ron1004 is offline
post #12 of 19 (permalink) Old 01-02-2015, 04:01 AM Thread Starter
xagrox's Avatar
Originally Posted by kville kia View Post
xagro,
wish I could help more... Never heard of a Kia Pride (only available outside USA), post with updates and the fix when you get one...
thankssss many many thank for u i know this model not exist in us because it s a tool for death than a car .. oh happy new year too my bro and wish all goods for you
xagrox is offline
post #13 of 19 (permalink) Old 01-02-2015, 04:05 AM Thread Starter
xagrox's Avatar
sounds like a messenger .. ok very very thanks for you proffessional super moderator icheck all thing soon .. thanks a lot .. and come back for get more helps
xagrox is offline
post #14 of 19 (permalink) Old 01-02-2015, 11:54 AM
Drives: '96 Camry v6 XLE, '00 Camry LE
Quoted: 125 Post(s)
Greetings,
You may also want to check the EGR system, IIRC there are hoses running to the solenoid on the firewall, and to the air box - they should be pliable,and secure..
Also check the vacuum hose on the Fuel Pressure Regulator (FPR), it's a short hose that runs from the FPR to the metal vacuum port running along the Intake Manifold,
* As a sanity check, I would pull and clean the EGR Valve - they do carbon up easy on this model, and check the vacuum diaphragm assembly to make sure it is moving freely / without restriction - have lots of Carb Cleaner on hand and a stiff nylon bristle brush to clean out the ports..
If you realize improvement, then next step would be to dial-in / adjust timing via adjusting the distributor, to smooth out the idle.
Hope this helps,
GottaCruise
( Former owner Ford Aspire / aka Kia Pride .. )
Last edited by GottaCruise; 01-03-2015 at 02:05 PM. Reason: Spelling foo - tooo mucchh eggnog ..
GottaCruise is offline
post #15 of 19 (permalink) Old 01-02-2015, 05:05 PM
kville kia's Avatar
Drives: '15 Soul 1.6L, '08 Sedona 3.8L, '03 Ford Escape 3.0L
Quoted: 37 Post(s)
No kidding, I used to own an Aspire... No frills good fuel economy car..... Ended up selling it to a friend who drove it till the wheels fell off (figuratively speaking)...
GottaCruise and xagrox like this.
Keep on rollin,
kville kia is offline
post #16 of 19 (permalink) Old 01-03-2015, 02:13 PM
Quoted: 125 Post(s)
With that 13" wheelbase, at least it didn't have far to fall.
Ours was a 'Salvage Yard Save' - much rehabbing to get it back to reliable running condition, was a fun project: if not for the transmission case getting cracked from road debris ( 2x4 in road, under water / not visible, during heavy rain - arrgh ), I'd still be driving it.. That car had great MPG w/ the 1.3 motor (sigh).
xagrox: I still have the (Ford Aspire) factory service manuals - if you need any specs., etc. let us know / post back, will try to help.
Regards,
GottaCruise
xagrox likes this.
OBD-II Codes:
post #17 of 19 (permalink) Old 01-06-2015, 12:49 PM Thread Starter
xagrox's Avatar
GottaCruise,
thanks my friend this days i have tests in university and i student at mathematic thread and tests are very hard .. after the end of this helly days .. i chek isc and egr system .. )
ford aspire engine with mine is same?! !! what about injection system ?! ... thank thank and much more thanks ...
xagrox is offline
post #18 of 19 (permalink) Old 01-09-2015, 08:34 PM
Quoted: 125 Post(s)
Greetings xagrox,
Hope your tests @ university go well - Mathmatics is a tough major, that's why I chose computer science ( let the computer do the math..
The fuel injection system should be similar, but I do not know if they are exactly the same, given we are in different countries / with the US EPA emissions regulations here.
I will get the factory manuals out and check the fuel injection system sections to see what's in the books / what will be involved to get that information to you.
* This will take a few days, very busy with work & travel, will post back by mid next-week ( Wednesday Jan. 14 2015 ),
Regards,
GottaCruise
Loyale 2.7 Turbo likes this.
OBD-II Codes:
post #19 of 19 (permalink) Old 01-09-2015, 10:37 PM
Loyale 2.7 Turbo's Avatar
Drives: 1985 Subaru Loyale (wagon), 2000 Kia Sephia (sedan), and 1969 Mercury Comet (coupé)
Quoted: 144 Post(s)
Red face let me share some offtopic info...
... Never heard of a Kia Pride (only available outside USA) ...
It was sold in USA as Ford Festiva / Aspire.
The Kia Pride is also Sold as Kia Delta in Latin America.
Kind Regards.
http://en.wikipedia.org/wiki/Ford_Festiva
Loyale 2.7 Turbo is offline
IAC failures and overheating? Sedonarunscrappy Kia Carnival & Sedona (2002 - 2005) 8 06-25-2018 10:56 PM
2005 Sedona Idle Issues kkmcglot Kia Carnival & Sedona (2002 - 2005) 1 11-28-2017 03:12 PM
high idle walker1 1G (1993 - 2002) Sportage 3 11-25-2017 02:35 PM
idle problem (Pride) dinges Other Kia Models 25 03-29-2010 10:25 PM
Engine stutters heavily when idle joebob 2G (1998 - 2001) Sephia 12 06-24-2007 03:17 AM
