Kia Elan Alignment Specs - Kia Forum
post #1 of 6 (permalink) Old 09-28-2014, 11:31 PM Thread Starter
lts2000ds's Avatar
Would anyone by any chance have the alignment specs for the Elan.
Cheers
"Cruisin"
lts2000ds is offline
post #2 of 6 (permalink) Old 09-29-2014, 09:09 PM
Quoted: 715 Post(s)
Here's the pages from the manual covering the four wheel alignment.
Note that you'll need shims for caster and camber adjustment - I guess you could make them.
I'll translate the key measurements shortly.
Front:
Toe Out 2.5 +- 2.5 mm
Camber -0.25 deg +- 0.25 deg
Caster +1.25 deg +- 0.25 deg
Rear:
Toe In 1.5 ~ 2.0 mm
Caster -0.5 deg
Name:	Screen Shot 2014-09-29 at 9.56.46 PM.jpg
ID:	31489   Click image for larger version
Name:	Screen Shot 2014-09-29 at 9.58.14 PM.jpg
ID:	31497   Click image for larger version
Name:	Screen Shot 2014-09-29 at 9.59.28 PM.jpg
ID:	31505   Click image for larger version
Name:	Screen Shot 2014-09-29 at 10.00.07 PM.jpg
ron1004 is offline
post #3 of 6 (permalink) Old 09-30-2014, 07:01 PM Thread Starter
lts2000ds's Avatar
Thanks Ron
PS....still trying to locate the extra set of pinion boots but can't seem to locate. We moved a couple of months ago and I for the life of me can't find them....sorry. If I locate I will let you know. The Moog ones that were listed in the thread work fine as well.
Cheers
Rob
"Cruisin"
post #4 of 6 (permalink) Old 11-16-2014, 08:07 PM
desert rat's Avatar
Drives: Elan M100, Evora, Focus.
Quoted: 3 Post(s)
Ron.
The suspension looks to be the same set up as fitted to the Lotus?
Castor shims are just swapped from front to rear. Number of shims remain the same.
I think I have a spare set of camber shims that I had remade a few years ago. somewhere if anyone needs them.
The Lotus manual gives dimensions of the shims.
Ron. would you be able to let me have a copy of the Kia service manual?
desert rat is offline
post #5 of 6 (permalink) Old 11-16-2014, 08:24 PM
Quoted: 715 Post(s)
Originally Posted by desert rat View Post
Ron.
My understanding is a few alignment settings are not the same, possibly to do with the Kia's higher ride height.
PM sent re: the service manual.
ron1004 is offline
post #6 of 6 (permalink) Old 12-02-2014, 05:20 AM
Don.Hasi's Avatar
Drives: Elan/Vigato/Roadster
Quoted: 12 Post(s)
The damper and spring sprecs are different to the Lotus. We have also distance rings at the rear to lift the back further. That said the aftermarket solutions like GAZ dampers works also with ours if you keep the springs for example.
The alignment from the Lotus could also serve as a target of the main setup, but I would highly recommend to go to a professional motorsport garage for a custom setup. It will allow you to double the cornering speed and to free the potential of the layout/car
Don.Hasi is offline
Wheel Alignment Specs ST Ken 4G 2016-2018+ Sportage 4 07-18-2018 09:50 AM
2014 Cadenza wheel alignment specs dearmosd Kia Cadenza Forum 0 10-07-2015 06:24 PM
Alignment specs unzip2000 2011 - 2013 (XM) Sorento Forum 0 06-09-2015 12:34 PM
Rear wheel alignment safety issue Larry Rowe Kia Sportage Forum 0 11-30-2009 10:09 AM
02 Sedona wheel alignment specs sscala Kia Carnival & Sedona Forum 2 09-25-2009 10:48 PM
