white smoke - Kia Forum
post #1 of 6 (permalink) Old 03-18-2014, 02:53 AM Thread Starter
white smoke
to my kia pride, theres a lot of white smoke coming out and cannot burn engine oil. what will i do?
naitsirhc is offline
post #2 of 6 (permalink) Old 03-18-2014, 08:28 AM
Drives: '96 Camry v6 XLE, '00 Camry LE
Quoted: 125 Post(s)
With Engine cold, check coolant level, fill top of radiator, check overflow tank and fill to (MIN) level as needed.. Have car checked for possible head gasket leak.
OBD-II Codes:
GottaCruise is offline
post #3 of 6 (permalink) Old 03-18-2014, 10:31 AM
PLP
PLP's Avatar
Quoted: 330 Post(s)
is the white smoke all the time or only on cold start?
and where do you live?
USA - paid, repair manual
Europe - paid, repair manual
PLP is offline
post #4 of 6 (permalink) Old 03-18-2014, 09:31 PM Thread Starter
i saw a oil leak to the engine. i live at las pinas.
post #5 of 6 (permalink) Old 03-19-2014, 08:45 AM
PLP
PLP's Avatar
Quoted: 330 Post(s)
Philippines ‎you say?
oil leak to the engine? You meant from the engine to outside? Or to the cylinders/pistons?
Pride, or Rio, has small engine.
If you add age to it you get stressed small engine that burns (leaks) oil. Hence, white smoke under some conditions.
If you see oil particles on the rear bumper or exhaust is oily, and you see the oil goes down (you must refill it once in a while) then you know what the problem is.
Coolant has a very distinctive smell when burned. Hence, it is easy to diagnose. Plus you will see coolant level going down as well.
PLP is offline
post #6 of 6 (permalink) Old 03-24-2014, 04:40 PM
Drives: Spectra 2006 (A/T 2000cc DOHC)
Quoted: 3 Post(s)
White smoke is usually something to worry about since it points to the oil being burned, is the oil level lower every time you check it?
Is it carbureted? If it is, clean carburetor with “carbucleaner” and ask your mechanic to tweak it.
If it is injected, you can try replacing the valve seals and gasket, it wouldn’t cost more than $200 including labor. That could help a little bit, but you have to start thinking in overhauling the engine.
esalas is offline
Huge white cloud of smoke happened when accelrating out of now where. anthonybeatz22 Kia Soul Forum 5 05-07-2018 06:32 PM
White Smoke from Exhaust jessiemusacchio 4G (2011+) Optima 4 03-23-2018 03:31 PM
White smoke clouds from exhaust GDI 3.3L Fan Kia Soul Forum 3 06-02-2016 01:28 PM
2005 Australian Sorento 3.5 V6 - White oily smoke richard300 2003-2010 Sorento Forum 3 06-30-2015 03:36 PM
