2011 Ferrari 599 GTO
7K views 4 replies 5 participants last post by  Andri86
#1 ·
2011 Ferrari 599 GTO Technical specifications:
* DIMENSIONS AND WEIGHT
* Length: 4710 mm (185.4 in)
* Width: 1962 mm (77.2 in)
* Height: 1326 mm (52.2 in)
* Wheelbase: 2750 mm (108.3 in)
* Front track: 1701 mm (67.0 in)
* Rear track: 1618 mm (63.7 in)
* Dry weight: 1495 kg (3296 lbs)
* Kerb weight: 1605 kg (3538 lbs)
* Weight distribution: 47% front – 53% rear
* Fuel tank capacity: 105 litres (27.7 US gal/23.1 UK/gal)
* Boot volume: 320 litres (11.3 cu ft)
* ENGINE
* Type: V12 – 65°
* Bore & stroke : 92 x 75.2 mm (3.62 x 2.96 in)
* Unitary displacement: 499.9 cc (30.51 cu in)
* Total displacement: 5999 cc (366.08 cu in)
* Compression ratio: 11.2:1
* Maximum power: 500 kW (670 CV) at 8250 rpm
* Maximum torque : 620 Nm (457 lbs/ft) at 6500 rpm
* GEARBOX
* F1 6-speed + reverse
* SUSPENSION
* SCM2 – Magnetorheological Supension Control
* TYRES
* Front: 285/30 ZR20″
* Rear: 315/35 ZR20″
* CARBON-CERAMIC BRAKES
* Front: 398 x 38 mm (15.7 x 1.5 in)
* Rear: 360 x 32 mm (14.2 x 1.3 in)
* ELECTRONIC CONTROLS
* CST with F1-Trac: Traction and stability control
* TPTMS: Tyre pressure and temperature monitoring system
* PERFORMANCE
* Maximum speed: over 335 km/h (over 208 mph)
* 0-100 km/h (0-62 mph) : 3.35 sec
* FUEL CONSUMPTION
* Combined cycle (ECE): 17.5 l/100 km
* CO2 EMISSIONS
* Combined cycle (ECE): 411 g/km
See less See more
2
