low temp water switch - Kia Forum
post #1 of 5 (permalink) Old 07-06-2010, 01:40 PM Thread Starter
NELSON30213's Avatar
have a 2001 kia sportage 2wd auto. the check enginge light came on and the reading was the low water temp switch. replaced it and after 90 miles the cel comes back on with the same thing. could it be the thermostat ? or what else should i check.
NELSON30213 is offline
post #2 of 5 (permalink) Old 07-06-2010, 08:01 PM
Pacosworld's Avatar
Quoted: 15 Post(s)
What code did you get? Not really seeing a low water temp. switch code on Kia Global Information System (KGIS). The switch you replaced, was it the Engine Coolant Temp sensor?
Mike AKA Paco
Pacosworld is offline
post #3 of 5 (permalink) Old 07-07-2010, 03:12 PM Thread Starter
low water temp
per the kia dealer there are two switches on has one lug and the other has two lugs on it and the one with two lugs is the low water temp switch. the car belongs to a buddy so i will have to get the code #. replace the switch with an autozone part and kia said that you must have their switch. so the switch is on order.
post #4 of 5 (permalink) Old 07-24-2010, 02:02 PM Thread Starter
the code i am getting is #0128 thermostat regulating temp below. i have replace the low water temp switch twice. what else could it be
thanks
nelson
post #5 of 5 (permalink) Old 07-24-2010, 07:03 PM
Pacosworld's Avatar
Quoted: 15 Post(s)
thanks
nelson
P0128 Coolant Thermostat Stuck Open
I'd take a closer look at the thermostat.
Mike AKA Paco
  Kia Forum > KIA Models > Kia Sportage Forum
HELP !! broken metal key in plastic ignition switch watcher 2003-2010 Sorento Forum 5 09-29-2017 01:17 PM
Need help finding a specific switch xxcrashxx 1G Kia Amanti & Opirus Forum 0 06-01-2017 08:59 AM
Keep out of the water until you have read this !!! pistnbroke 2003-2010 Sorento Forum 8 06-07-2010 04:28 PM
Water temp sender jr? Jimbug 2G (1998 - 2001) Sephia 2 10-31-2007 06:47 PM
Head temp sensor wedge 1G (1993 - 2002) Sportage 1 02-01-2007 05:24 PM
