Where is the radiator drain plug? - Kia Forum
post #1 of 7 (permalink) Old 05-30-2010, 12:34 PM Thread Starter
Question Where is the radiator drain plug?
I searched for almost an hour under the vehicle (KIA Sportage 2008). Can someone please help me point out in the right direction?
blanchard is offline
post #2 of 7 (permalink) Old 05-30-2010, 03:05 PM
Memorial Super Moderator
pulsar86's Avatar
Quoted: 3 Post(s)
If the Sportage is fitted with a drain it most likely is only a plastic phillips headed screw positioned low in the bottom radiator tank, my Cerato has a drain of that type. I'm sure a fellow owner will respond and let you know for sure. I think your owners handbook should have a section about it.
pulsar86 is offline
post #3 of 7 (permalink) Old 05-30-2010, 03:43 PM Thread Starter
I looked up the owners manual, I do not see any information on the drain plug location. I have another car (Hyundai Elantra) and I have no problem finding that plug in it.
post #4 of 7 (permalink) Old 05-31-2010, 07:23 PM
pulsar86's Avatar
Quoted: 3 Post(s)
Come on fellow owners , is there a drain fitted?
pulsar86 is offline
post #5 of 7 (permalink) Old 05-31-2010, 08:33 PM
Pacosworld's Avatar
Quoted: 15 Post(s)
I don't believe this has the phillips head drain plug in the bottom of the radiator. Look on the passenger side of the radiator (easier to view from the bottom). It has a regular drain cock. Best of luck.
Mike AKA Paco
Pacosworld is offline
post #6 of 7 (permalink) Old 06-05-2010, 02:13 PM
arkansasfish's Avatar
Drives: 98 Sportage/ previously 01 Sportage
Gallery: 2
I was looking for mine just yesterday. I stuck my head under there and seen a white plug. But my radiator is not the original, it might not even be from a sportage.
I was able to add antifreeze to a full radiator without draining it. I used a turkey baster. While the car was off, I sucked up as much fluid as I could, then added antifreeze. Then I started the engine. Using the turkey baster, I kept taking out and putting in the fluid. Within 15 minutes, I had half the jug in there. BUT the water started getting pretty HOT.
I own my second Sportage so I must really like em. I consider this one to be my second husband. Main issue with mine was the Timing Key(woodruff)
arkansasfish is offline
post #7 of 7 (permalink) Old 06-13-2010, 05:28 AM
Gallery: 2
Passenger side, back of radiator at bottom. Mine has "butterfly shaped" things on it used to turn it. I can see mine by squatting at the front right tire, look through wheel weld in front of the tire.
  Kia Forum > KIA Models > Kia Sportage Forum
Broken & stuck glow plug mulletronic Kia Cee'd Forum 0 01-20-2016 12:48 AM
Changing headlights eray156 3G 2011 - 2016 Sportage 14 01-06-2016 01:28 PM
Brake Controller - Where the Ding Dang is the Receiver Plug??? DeanCHS1980 Kia Mohave & Borrego 3 12-18-2015 11:58 PM
2014 Sorento LX OBD II plug was cut off! dingode 2014 - 2015 Sorento Forum 13 08-14-2015 10:18 PM
Engine stutters heavily when idle joebob 2G (1998 - 2001) Sephia 12 06-24-2007 03:17 AM
