Need help with 2012 Soul door lock wiring/relays - Kia Forum
post #1 of 15 (permalink) Old 05-21-2019, 05:36 PM Thread Starter
89Vette's Avatar
Drives: 2012 Kia Soul
I am digging into a power door lock problem on my daughter's 2012 Kia Soul. The doors intermittently (rarely) unlock using any of the interior door switches -- as well as the key fob. I am referring to all doors EXCEPT the driver's door. That works...as well as the door lock functions.
So far, I'm finding posts (on the net and in this forum) that lead me to believe Kia was DUMB enough to hardwire a door unlock relay into the fuse (junction) box. If true, I'm already super-pissed! This alone negates a growing infinity for Kia versus Toyota -- in terms of perceived reliability/design -- but I digress! LOL
My best guess -- after looking at door lock schematics and preliminary testing is that the "2-turn door unlock relay" is going bad. It can be seen in this diagram....
When working properly, a 2012 Soul requires a second push of the key fob to unlock passenger doors and hatchback. I am interpreting the "2-turn door unlock relay" as the component that triggers the lock/unlock actuators in each door (and hatch). When this relay malfunctions, the doors/hatch do not unlock. And, without a key unlock for the hatch, the idiocy of Kia's design becomes apparent: The hatch won't open, can't be opened with a key, and the repair cost exceeds $1300! That's because Kia charges 10 hours to replace the junction box.
As a preliminary test, I jumped a second battery to her car. The unlock function worked better...but still intermittently. My conclusion is the higher current (from 2nd battery) increased chances of the "2-turn unlock relay" of actuating. I could surmise a ground/wiring issues TO that relay but everything else works. I would suspect common ground AND the thing is reportedly hard-wired into the junction box -- from what I gather.
Having just graduated from college (with loans), you can appreciate not wanting to spend $1300 to replace the junction box -- nor can I afford to do that for her. However, I claim to be "clever and handy".
My thought is to bypass the 2-turn unlock relay with a new relay. It would sit outside the junction box and be triggered by the "door unlock relay" -- which I presume to be the driver's door unlock relay. If successful, ALL doors would unlock as originally wired though a single-press of the key fob would also unlock all doors. This is acceptable -- in lieu of the alternative....e.g., spending $1300 OR replacing the junction box myself!!!!
This thread (in another forum) shows some wiring for the addition of keyless entry. I'm looking for supplemental information....and need it within a couple of days. My daughter is moving out-of-state so I hope to affect repairs quickly. My hope is to identify the correct wires to install an outboard relay.
Here is my goal:
Please help me identify which wires to cut/spice in order to add an outboard relay. In post #11 (of the UNLINKABLE, NEW POSTER RULING I HAD TO REMOVE), the pic showed WHAT I BELIEVE may be the correct blue/orange, red/orange, and brown (brown/white?) wires used to ground the energizing side of the door relays. My idea is to ground a new, outboard relay using the "signal" from the blue/orange door unlock relay (going under the assumption this is the driver's door unlock relay). The slave side of the relay is where I'm less clear.....
In the main pic for this thread, there are 3 "legs" to the slave side of the "2-turn relay": Blue, Black and power. I haven't figured this out yet. Please identify these wires and how you think the actuators are energized by the slave side of the relay? (This would include saying what each of the blue, black, and power terminals are for?
Thanks! (FWIW, I also joined the Soul forum but need to be "accepted" before posting there).
89Vette is offline
post #2 of 15 (permalink) Old 05-21-2019, 05:45 PM Thread Starter
89Vette's Avatar
post #2 (toward 10 min before including pic?)
89Vette is offline
post #3 of 15 (permalink) Old 05-21-2019, 05:46 PM Thread Starter
89Vette's Avatar
Geez...How did I post a pic in my OP but now I can't because my count is too low? post #3
89Vette is offline
post #4 of 15 (permalink) Old 05-21-2019, 05:47 PM Thread Starter
89Vette's Avatar
Can't believe I have to play these games to avoid scammers, get into a forum with reasonable haste, and get answers. By the way, I hope to provide HELPFUL info to others with this problem! Geez!!!!
89Vette is offline
post #5 of 15 (permalink) Old 05-21-2019, 05:48 PM Thread Starter
89Vette's Avatar
Geez...How did I post a pic in my OP but now I can't because my count is too low? post #5 (of 10 required to post a pic)?
89Vette is offline
post #6 of 15 (permalink) Old 05-21-2019, 05:49 PM Thread Starter
89Vette's Avatar
Sorry guys for this B.S.! Hope this thread can be edited for clarity when problem is resolved.....mostly for YOU GUYS!!!!
89Vette is offline
post #7 of 15 (permalink) Old 05-21-2019, 05:50 PM Thread Starter
89Vette's Avatar
I've been in (joined) other forums without this much angst!
89Vette is offline
post #8 of 15 (permalink) Old 05-21-2019, 05:52 PM Thread Starter
89Vette's Avatar
Let's see... 3 more posts before I can post a pic?
89Vette is offline
post #9 of 15 (permalink) Old 05-21-2019, 05:52 PM Thread Starter
89Vette's Avatar
post #9 for the requirement
89Vette is offline
post #10 of 15 (permalink) Old 05-21-2019, 05:53 PM Thread Starter
89Vette's Avatar
89Vette is offline
  Kia Forum > KIA Models > Kia Soul Forum
2012 Soul Driver Door Unlock Issue NutFlush920 Kia Soul Forum 1 01-21-2019 08:03 PM
Aftermarket radio 2012 Soul with premium audio NutFlush920 Kia Soul Forum 0 12-25-2018 05:14 PM
2012 kia soul 2.0 random misfire gameover1173 Kia Soul Forum 6 10-16-2018 01:40 PM
2012 Soul - looking for driver tail light bezel Fezzgig Kia Soul Forum 1 08-19-2016 09:21 AM
