2015 Soul idles rough when brake applied - Kia Forum
 2Likes
  • 1 Post By ron1004
  • 1 Post By ron1004
post #1 of 9 (permalink) Old 03-08-2019, 06:59 PM Thread Starter
Drives: 2008 Rio
I donít really understand it, but our 2015 Soul will begin to idle ďroughĒ when we apply the brake. Putting it in neutral or park makes it go away. Turning off the headlights seems to help a little bit. Itís almost as if having the break lights on causes too big a load on the engine due to the alternator. Does this make any sense to any one?
mvanhorn is offline
post #2 of 9 (permalink) Old 03-09-2019, 12:13 AM
Drives: 2015 KIA Sorento LX 2.4L & 2018 Chrysler 300 Limited
Quoted: 115 Post(s)
I would into a vacuum leak as a possible cause as your brake booster works off of vacuum check your lines for leakage as it could be a cause of your rough idle when applying your brakes.
jetech00001 is offline
post #3 of 9 (permalink) Old 03-09-2019, 06:54 AM Thread Starter
Drives: 2008 Rio
Iíll check the line, but how does a vacuum leak get affected by turning the headlights off? And wouldnít a vacuum leak affecting the break booster causes us trouble with braking?
mvanhorn is offline
post #4 of 9 (permalink) Old 03-09-2019, 07:14 AM
Quoted: 704 Post(s)
Three things I'd look at, vacuum leak, the check valve in the vacuum line to the brake booster, and the Idle Speed Control valve (ISC / IAC).
If the ISC / IAC is not working, the idle speed will not be automatically adjusted when loads change, such as the lights or AC.
jetech00001 likes this.
ron1004 is offline
post #5 of 9 (permalink) Old 03-09-2019, 02:17 PM
Quoted: 115 Post(s)
post #6 of 9 (permalink) Old 03-09-2019, 04:23 PM Thread Starter
Drives: 2008 Rio
By any chance, do you have a source that shows where the Idle Speed Control valve (ISC / IAC) is on a 2015 Soul? I canít find it in any diagram, or even find a replacement from the parts places.
That seems like the most likely candidate Iíve seen so far, since itís load-related. And it ideal fine when the lights are off, etc.
mvanhorn is offline
post #7 of 9 (permalink) Old 03-09-2019, 04:45 PM
Quoted: 704 Post(s)
If the 2015 Soul is your vehicle, please update your user profile.
At around the age of your vehicle Kia and others, moved to "drive by wire" throttles, and these eliminate the need for an ISC/IAC.
If the vacuum leaks and the brake booster vacuum line check valve are ruled out, and you don't have an ISC, then you'll need to get a scanner that can display the throttle demand and watch if its reacting correctly to idle load changes and sending position demand signals to the throttle.
ron1004 is offline
post #8 of 9 (permalink) Old 03-10-2019, 07:22 AM Thread Starter
Drives: 2008 Rio
It isn't my vehicle. And what difference does that make?
It must not have an ISC, then, so I can't seem to find it anywhere. And it isn't throwing a code about it, either, so maybe that isn't it.
mvanhorn is offline
post #9 of 9 (permalink) Old 03-10-2019, 07:55 AM
Quoted: 364 Post(s)
IF this is a GDI type motor(I'm not certain) It could have poorly spraying injector(s) and need a good fuel additive treatment. My next thought would be a "dirty" (carboned up) throttle bore and butterfly plate, that a good spray cleaning with appropriate fluid would help.
MIA KIA 09 is offline
  Kia Forum > KIA Models > Kia Soul Forum
Brake issue on 2015 Sportage - 3 yr Lease started May 2015 cdkscully 3G 2011 - 2016 Sportage 2 11-26-2016 05:05 PM
2010 KIA Soul Brake Proportioning Valve PiperLarry Kia Soul Forum 3 05-11-2016 04:50 AM
HELP - Install of Brake Controller 2015 Sportage - Elusive Red Wire Tap in Point yzripper 3G 2011 - 2016 Sportage 4 05-05-2016 04:55 AM
2015 Kia Soul and Android Auto??? mattmanion Kia Soul Forum 2 10-27-2015 02:05 PM
Cold air intake for 2015 kia soul 2.0 FreshSoul Kia Soul Forum 7 09-30-2015 10:33 AM
