2012 Kia Soul !, Cranks but won't start - Page 2 - Kia Forum
 3Likes
LinkBack Thread Tools
Old 01-23-2019, 03:46 PM Thread Starter
Drives: 2012 Soul !, 2014 Forte LX
Quoted: 12 Post(s)
I don't see a way to edit the original post, so please be aware that I mis-used crank to mean "running" in a few places.
CSShelton70 is offline
Old 01-23-2019, 04:00 PM Thread Starter
Quoted: 12 Post(s)
Originally Posted by MIA KIA 09 View Post
When you turn the key to the run(not crank) position, do you hear the in tank fuel pump whirr for a couple seconds? If you have spark, then the injectors should also be firing when cranking the motor. but if the pump is not supplying fuel it won't start.
You could try a shot of starting fluid or carb spray down the intake and see if it fires off on that (till the spray is used up). If it does, then I would say that indicates a bad fuel pump or wiring to it!
I did hear the whirring noise, but I don't have any starter fluid handy. I'll get some tonight and give it a try tomorrow morning. Can I just un-do the rubber/plastic housing over the air-filter, spray some up the tube and then lock it back down or do I need to find someplace closer to the engine to spray it?
Old 01-23-2019, 04:11 PM
Quoted: 256 Post(s)
... You could try a shot of starting fluid or carb spray down the intake and see if it fires off on that (till the spray is used up). If it does, then I would say that indicates a bad fuel pump or wiring to it!
Memo to self: make sure which CRANK we're talking about, even when it seems like there's no doubt
Anyway, try the above suggestion, which might have gotten lost in the shuffle. Doing this test will not resolve your vehicle's problem, but it will at least get you moving in the right direction.
ron1004 likes this.
kiaguy002 is online now
Old 01-23-2019, 04:14 PM
Quoted: 364 Post(s)
Originally Posted by CSShelton70 View Post
Apologies that I don't know the preferred terminology. I thought crank mean that the engine was running. I'll go back to the original post and edit my mis-use of Crank.
Here is the current status: I put the key in, I turn the key, the engine turns over multiple times, but it will not get to "running". It may chug a time or two just to tease me, but it never runs.
Battery: I had it check by 2 different stores ( O'Reilly and Advanced Auto) - both said good both in volts and amps. I've replaced both battery terminal connectors ( because both had corrosion and the nuts used to tighten them had seen a bit of wear -- and I cleaned all the corrosion off the battery terminations with one of those wire brush tools.
Go back and read post #6 then, Turn the key to the RUN position(dash lights up) and listen for a short "whirring sound from the gas tank area. if not you may have a bad fuel pump(or out of gas). Then try a short spray of starting fluid(a spray can) directed into the air hose from the air cleaner and try cranking the starter motor. IF it fires off and runs(till that shot of fluid is used up) then then fuel pump is not working and needs to be checked for why not.
Last possibility is the timing belt may have jumped and by the year of your ride is overdue for replacement to prevent catastrophic engine damage if it should jump or break(if it has NOT been replaced already).
MIA KIA 09 is offline
Old 01-25-2019, 10:58 AM Thread Starter
Quoted: 12 Post(s)
Thumbs up
Excelsior! The starter fluid allowed the engine to catch and it started. Blew a LOT of white smoke out the tailpipe at first, but it running! Let it run for 2 minutes, turned it off, and was able to start it again. Same test after 15 minutes of rest - and it started again.
Thanks for everyone's help - and instruction on the correct definition of crank vs start.
I'm back to the original problem now, so I'll be posting a new thread for it.
Old 01-25-2019, 11:07 AM
Quoted: 704 Post(s)
Glad you're making headway, but before you start a new thread tell us what the "original problem" is.
ron1004 is offline
Old 01-25-2019, 11:10 AM Thread Starter
Quoted: 12 Post(s)
Sorry, I just posted it. It's the intermittent blower I may have mentioned in the original post of this thread.
Old 01-25-2019, 11:12 AM
Quoted: 704 Post(s)
OK, its not related to this.
ron1004 is offline
Old 01-25-2019, 11:13 AM
Quoted: 364 Post(s)
That is great news to hear about it getting the engine running! sounds like you had a "flooded" condition as the root cause.
Word of warning..I'm not big on the interior wiring on these Kia's...so don't expect to see me posting up on your forthcoming thread...
Old 01-25-2019, 11:59 AM
Quoted: 256 Post(s)
.... The starter fluid allowed the engine to catch and it started. Blew a LOT of white smoke out the tailpipe at first, but it running! .....
Glad to read it's running now, but it sounds like there was either water or coolant in the cylinders causing the problem. So you should check the coolant level now, and regularly in the future.
ron1004 likes this.
  Kia Forum > KIA Models > Kia Soul Forum
2000 Kia Sportage Cranks but will not start rdonovan1 1G (1993 - 2002) Sportage 7 01-08-2018 06:44 AM
2010 kia soul cranks but no start peterharewood Kia Soul Forum 1 12-15-2016 03:24 PM
2012 Kia rio wont start at times. chefmichael 3G (2012 - 2017) Rio 6 10-18-2016 01:47 PM
2012 Sedona Intermittent Cranks But Will Not Start 2012Sedona Kia Carnival & Sedona 2006+ 0 06-21-2015 10:30 PM
2001 rio automatic cranks, wont start wierd myposhak 1G (2001-2005) Rio 2 10-06-2009 01:20 PM
