New owner of Kia Borrego LX 3.8 and had a few - Kia Forum
post #1 of 17 (permalink) Old 11-10-2011, 01:17 PM Thread Starter
Questions. 4WD. It has 13K miles on it.
I have always changed my oil in the GM Vehicals. This is my first import and I wanted to try to change the oil and filter. I read through the owners manual and they pretty much say take it to a KIA dealership. I did see its a canister type of filter and not a screw on type.
How do you replace the filter?
I live in Wisconsin so its cold up this way. I've always used 5w-30 oil. I see in the manual it says 5w-20.
Does it matter?
It also says Change axle oil at 22k. Is this correct? Is this something I can do myself or should I take it somewhere to get it done?
Transmission Fluid? Doesn't say how often in the manual but the Dealer recommends it at 30k.
Transfer case Fluid? How often on this?
Does this have a Timing Belt that has to be replaced at 100k?
Thanks for the help. I just want to make sure Im doing this at the right time and not doing more than I should be.
Thanks Steve69
Steve69 is offline
post #2 of 17 (permalink) Old 11-10-2011, 03:28 PM
import vs domestic really doesn't make any difference. I've owned lots of both. Generally imports are EASIER to work on, at least in my experience. Domestics do some really dumb things when it comes to common stuff to work on, the engineers who design it never actually do the work. (union laws prevent them from actually turning a wrench and seeing how their design works!)
Anyway, nevermind that above! The oil filter is simple to change, easier than any other vehicle you have owned. There is just a container up on top the engine that holds the filter. Screw the top off, remove the old cartridge, and drop in the new one. They are a little expensive though ($11 IIRC), and only available at a dealership.
As far as oil, 5w-30 is fine. Almost every single vehicle that specs 5w-20 doesn't actually NEED 20, it was done to increase the mileage at the possible expense of engine longevity. As long as it makes it past the warranty interval, the mfg is good to go. Mileage goals are tough to hit though, and every bit helps.
smokingcrate is offline
post #3 of 17 (permalink) Old 11-10-2011, 04:29 PM
GregsKia's Avatar
Drives: 06 Sedona LX, 06 Sedona EX, 14 Forte EX, 11 Sportage EX, 11 Forte 5-door SX, 15 K900 VIP+
Quoted: 19 Post(s)
The engine has a timing chain, so you don't need to change it. As for the oil, I personally recommend 5W20. I have the same engine in my Sedona, and it has 162,--- miles on it without any major problems. Have fun with the Borrego, it's a great vehicle!
GregsKia is offline
post #4 of 17 (permalink) Old 11-11-2011, 01:36 PM Thread Starter
So with the Oil Filter. I unscrew the plastic top and pull the old filter out. I see there is seals with the filter kit. Where do those go?
Is there grease jerks that have to be greased. U joints?
Thanks again for the help.
Steve69
Steve69 is offline
post #5 of 17 (permalink) Old 11-11-2011, 01:45 PM
GregsKia's Avatar
Quoted: 19 Post(s)
There are two gaskets. One goes around the top by the threads, the other one goes around the bottom. Make sure (obviously) that you remove the old gaskets first. They are tricky to get off - I use a pocket knife to cut them off. Make sure the new gaskets are seated in the grooves. I am not sure if you have to or not, but I have always put some of the new oil on the new gaskets, just like you would on the gasket of a spin-on type.
GregsKia is offline
post #6 of 17 (permalink) Old 11-11-2011, 02:03 PM
cobra259's Avatar
Quoted: 375 Post(s)
Steve69
There is also a drain plug gasket included with the oil filter..at least there is with the Kia filter. As far as I know, there is no greaseabul fittings.
cobra259 is offline
post #7 of 17 (permalink) Old 11-14-2011, 10:25 AM Thread Starter
Thanks for the info guys.
Saturday I took a look and I couldn't find where the Oil filter housing is locacted at. Is it hidden?
Thanks again.
Steve69
Steve69 is offline
post #8 of 17 (permalink) Old 11-15-2011, 12:16 PM
Drives: 14 Kia Sorento (V6 EX AWD), 2013 Nissan Altima SV
You might want to let the dealer do it.
Rick2456 is offline
post #9 of 17 (permalink) Old 11-16-2011, 09:52 AM Thread Starter
I might just do that. See if I can watch them do it to see how its done.
Steve69
Steve69 is offline
post #10 of 17 (permalink) Old 11-16-2011, 12:35 PM
Drives: 2008 pontiac G6, 2009 Kia borrego
On v6 versions, the filter housing is located on the upper left part of the engine but you need to take the engine cover off first to do that. Once its off, you'll see a black housing with a knob on top. To unscrew it, I used a crescent wrench and that's it. To finish the process, just do what the other members have mentioned above.
ex v6 is offline
