(automatic) Tilt Steering - Kia Forum
post #1 of 10 (permalink) Old 07-25-2011, 02:46 PM Thread Starter
Hello,
Before I call the dealer... I noticed my memory on my electric tilt steering isn't working anymore. When I hit on of the memory buttons my seat and mirrors will move but not the wheel anymore. It works fine if I move it with the switch on the steering wheel itself.. Up/down and In/out.
...Any Ideas??
flash828 is offline
post #2 of 10 (permalink) Old 07-25-2011, 07:25 PM
make sure the wheel is where you want it & shut the car off & pull the key wheel will go up, put key back in & should work..
waleye is offline
post #3 of 10 (permalink) Old 07-26-2011, 06:39 AM Thread Starter
Thanks, but no luck. I tried the setting where you take key out and seat will go back and wheel will go up. Seat goes back, wheel doesn't move.
flash828 is offline
post #4 of 10 (permalink) Old 08-09-2011, 09:39 PM
BorregoV8's Avatar
Drives: 2003 Ford Taurus Centennial, 2009 Kia Borrego ExV8
I have had the same problem. The steering wheel will tilt up then back down to where it should be after the key is reinserted. But when I change drivers, the wheel does not change. I am going to tell the dealer when I take if for an oil change
BorregoV8 is offline
post #5 of 10 (permalink) Old 08-23-2011, 02:06 PM Thread Starter
Ever get it checked out? I have not yet. They need the car for a while to trouble shoot. Haven't had time yet.
BTW...we are just over the river from you.
flash828 is offline
post #6 of 10 (permalink) Old 09-18-2011, 11:02 AM
Were you able to have this fixed? I have the same intermitent problem: sometimes the steering wheel doesn't move when changing from setting one and two, sometimes it does...
DomH is offline
post #7 of 10 (permalink) Old 09-22-2011, 06:59 AM Thread Starter
Not yet, hope to do by next week. My Nav just started to lock up so am hoping to get this fixed at the same time.
flash828 is offline
post #8 of 10 (permalink) Old 12-04-2011, 01:37 PM
Drives: 2010 Borrego ExV8
Tilt steering
I sometimes have the same problem. When the wheel does not move down and forward to my driving position, I manually set it and then reset the preset button on the door. This works for a while, but no permanent solution.
Duane R is offline
post #9 of 10 (permalink) Old 12-29-2011, 11:33 AM
Drives: 09 Borrego EX V8 2WD
Quoted: 3 Post(s)
Hyundai also having steering wheel tilt problems
My Borrego has also had intermittent steering wheel tilt problems. I came across this info concerning the same problem on the Hyundai Genesis (I'm sure most know Kia is a subsidiary of Hyundai). They also had a temporary fix.
HavasuPaPa is offline
post #10 of 10 (permalink) Old 06-06-2014, 02:24 PM
Drives: Kia Borrego & Sorento
My Borrego had/has same problem. 2 years ago the dealer replaced the safety limit switch to get the manual tilt switch on the steering column to work. 6 months later, the dealer replaced the entire steering column assy. (under warranty) to fix this issue. Dealer said there were no replacement parts for the tilt/telescope feature. They talked to the KIA Service Repr. who told them that KIA had NO PROBLEMS with this system. Now the same problem is SLOWLY coming back.
fundsteve is offline
Power steering high pressure hoses removal issue, both high and lower hoses. Learning 2G (1998 - 2001) Sephia 2 05-29-2018 07:07 PM
Auto Tilt Steering ELMO4635 Kia Mohave & Borrego 0 11-20-2017 12:13 PM
2013 Steering Electric Tilt Problem Abdulla79 Kia Mohave & Borrego 1 01-10-2017 03:21 AM
Automatic Reverse Mirror Tilt Module for kia cars renn_77 Parts For Sale / Trade 1 11-27-2016 12:14 AM
Design for KIA: Automatic Reverse Mirror Tilt Module renn_77 Parts For Sale / Trade 0 08-17-2016 08:24 PM
