This Was NOT Good ! - Kia Forum
post #1 of 21 (permalink) Old 11-05-2009, 04:09 AM Thread Starter
EXV8's Avatar
This Was NOT Good !
Started the Borrego this morning and while starting it made a strange sound then the fun began sounded like it was running on 4 of its 8 cylinders and was shaking and bucking all the while the check engine lamp was flashing away like a beacon of distress then all of a sudden it just leveled out and everything was fine again. Looks like a trip to the dealer is in order. Funny thing the day before when I started it, it started just fine but let out a HUGE cloud of smoke!
EXV8 is offline
post #2 of 21 (permalink) Old 11-05-2009, 11:27 AM
Drives: 1983 JEEP CHEROKEE WIDETRACK, 1987 FORD MUSTANG ASC/MCLAREN, 2001 DODGE DAKOTA QUAD CAB 4X4
Definitely Take To Dealer....should Have Stored Codes From Check Engine Light In History...
KIAPARTSOURCE is offline
post #3 of 21 (permalink) Old 11-05-2009, 01:28 PM
Memorial Super Moderator
pulsar86's Avatar
Quoted: 3 Post(s)
Definately go to the dealer. It sounds like maybe something to do with cam position sensor or similar.
pulsar86 is offline
post #4 of 21 (permalink) Old 11-05-2009, 04:51 PM
smuook's Avatar
Drives: 2009 Borrego
Gallery: 5
On my old CTS, I lost half my cylinders due to a intermittent ground in the ignition system. It felt like the car was misfiring. If it comes and then mysteriously goes away, my bet is that it is an electrical gremlin. Hard to tell though with modern engine management systems. Good luck.
smuook is offline
post #5 of 21 (permalink) Old 11-05-2009, 08:09 PM
Maybe it's those HID's you installed? ... hehe just joking..
Sounds bad though, hopefully they'll figure it out quick for you.
catalin is offline
post #6 of 21 (permalink) Old 11-05-2009, 11:17 PM Thread Starter
EXV8's Avatar
So They blamed it on me
Dealer said that it happened because the night before when I started the truck just to move to the other side of the driveway I didn't warm it up enough before shutting it off, hence some valve in there somewhere didn't close all the way and allowed raw fuel to leak into the cylinders all night hence flooding out the motor. They said never shut the motor off cold if it didn't run for at least 5 minutes prior. Said there were traces of fuel in the oil also and they changed that too to the tune of $38
EXV8 is offline
post #7 of 21 (permalink) Old 11-06-2009, 12:37 AM
pulsar86's Avatar
Quoted: 3 Post(s)
The dealers reason shouldn't happen as the injectors should close fully when the engine is turned off whether it is hot or cold.
pulsar86 is offline
post #8 of 21 (permalink) Old 11-06-2009, 09:55 AM
WTF! Did you tell them you turned it off too quick?? Regardless though really? Does that mean that hundreds of these vehicles could literally fall apart if you run them less then five minutes.... garbage. Next time shrug your shoulders man and tell them to fix it.
catalin is offline
post #9 of 21 (permalink) Old 11-06-2009, 04:07 PM
smuook's Avatar
Gallery: 5
The valves are for intake air and exhaust fumes... has nothing to do with the fuel except that they are timed with the fuel injectors. Not sure if I buy their diagnosis, but whatever. Keep you receipts and make notes of who you talked to and what was said. Hopefully it won't happen again.
smuook is offline
post #10 of 21 (permalink) Old 11-06-2009, 05:18 PM
Sounds like a new dealer should be searched if possible (doubt it). I'd be doing the shoulder shrug too and say "gas in oil? sounds like a design flaw". If it happens to me i'm gonna play completely dumb. How many times do you drive your car for under 5 minutes cold over the life of the vehicle. If its so electronic and smart, it should shut itself off after its properly warmed up.
I gotta say, my V8 doesn't idle completely smooth unless I rev it up around 1000 rpms. I don't mind the rumble (sounds nice and seems normal) but I sorta thought it would be more smooth.
I have also had a few starts where it turned over quite a while until it started, and this was from cold starts.
2009 Borrego LX 2WD V8 Limited Black
flyguycali is offline
Good KIA tech/dealership in GTA. whylee 2016+ Sorento 0 05-28-2016 10:46 AM
Good Morning Everybody !:D DionisioLuis New Member Area/Introduction 4 10-15-2015 05:36 PM
Good Morning, Good Afternoon & Good Evening BlackVoid New Member Area/Introduction 3 09-18-2015 02:30 PM
Did i get a good deal? rosh 2016+ Sorento 14 08-03-2015 08:27 PM
Is that good or bad? :( Sally Cha Cha 3G (2012 - 2017) Rio 3 08-01-2015 08:00 PM
