LOCK ASSEMBLY-STEERING & IGNITION faulty - Kia Forum
post #1 of 1 (permalink) Old 02-07-2019, 03:46 PM Thread Starter
Drives: Kia Mohave 3.8 EX 2009
hi all
LOCK ASSEMBLY-STEERING & IGNITION was giving me hard time for the last few months
i was having the message
press button while turn steering' so i was shaking the steering and i was good to go
few days ago dashboard dark no response from the car
time to replace the unit ,original part number installed 819002J700,kia confirmed that this Part was discontinued and new part number 819002J710 to be used insted ,part ordred received connected bingo engine started car agai back to life
with the new part installed i m getting a message check steering lockafter a ride whenever i open the door ,seems like the steering lock function is inop
anybody could confirm if the 2 units are interchangeable
since the new unit is upgraded ,does it require a computer configuration in KIA workshop or a rewiring of the connector
guys please anybody has a wiring diagram for the kia borrego/mohave before and after 2012 to compare the wiring of the 2 parts if different ,a wiring would help me to find the root cause (wiring check.....)
replacement could be done by anaybody good with his hands steering column to be removed,i m working on video that could help
Kia Mohave 3.8 EX 2009 GCC specs and 150000 KM
samir messaoudi is offline
Door won't open from outside. How to replace the door actuator assembly. paulstaf 2011 - 2013 (XM) Sorento Forum 3 03-31-2019 08:58 PM
Two questions: Ignition Lock Cylinder corn55 2011 - 2013 (XM) Sorento Forum 1 02-05-2019 09:39 PM
Power steering high pressure hoses removal issue, both high and lower hoses. Learning 2G (1998 - 2001) Sephia 2 05-29-2018 07:07 PM
2003 Sorento - Ignition Lock / Key Cylinder Switch replacement Gilles31 2003-2010 Sorento Forum 1 06-10-2015 04:45 PM
Kia Cerato 1.6 Steering Lock?? Matty S Kia Cerato, Shuma & Spectra Forum 1 11-09-2006 05:47 PM
